Spark Plug Replacement at mechanic or DIY?
My var had 55K and I'm taking it for a custome tune next month so, just going through the checklist. The only thing my car is missing is possibly new plugs at the time. Went to my mechanic and the amount he quoted me for labor is crazy high. What have others on here paid for the labor or, is the DIY that difficult?
It seems to be at least a two or three hour work and that's having all of the tools ready ahead of time.
My biggest concern is taking off the throttle boddy and messing something up badly. Comments?
on
I did my spark plugs for the first time at 67k miles. The DIY was pretty easy, took me about two hours (I had never done them before on the G). I took off the intake and loosened all wires to make the install easier. If you take the throttle body off, all you have to do is follow the throttle body reset procedure. I don't have the link for the reset, but it can be found easily with a simple search. I will post up the DIY for the spark plugs though... Hope it helps!
http://my350z.com/forum/engine-drive...huge-pics.html
http://infinitihelp.com/diy/gcoupe/e...nsimission.htm
Thank you Cubs. If I don't need to take off the throtle body, I just won't. My mechanic quoted me $125 for the job and I thought, that's quite a bit more than what I was lookingto pay. I also have a 2K Se MAxima and have swapped out the plugs numerous times. This just looks a tad bit more complicated.
ByThaBay's video is what I used to DIY. I took three hours but ate lunch between. The hardest one to get was the rear pass plug b/c I had to really squeeze the coil pack out between the looms.
If you DIY: you can just remove the intake between the filter box and TB, then loosen all the wire looms at the brackets than connect them to the valve covers like the video I mentioned above.
If you can get it done for 125 including plugs, then it isn't that bad. I like knowing it was done by me and that things were torqued to spec, etc. My rear driver spark plug hole has oil in it. I'm not going to fix it until it causes a problem so I sucked the oil up with a rag, pulled the plug, and put a copious amount of plug boot grease to prevent oil from getting to the terminal.
Reminder... if you DIY remember to buy anti-sieze and plug boot grease.
Good luck.
its easy remove the intake and unbolt the the main harness so you can move it out of the way and just make sure to unhook one coil pack at a time and do the spark plug and then plug it back in and move to the next one
it is a pretty simple DIY and just do my procedure to make sure you don't mix up wires and have misfire which can ruin your cats... but its a good DIY
GOOD LUCK
![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
GOOD LUCK
Yes, definitely check the gap on the plugs. Like everyone before has said, it's a pretty straight forward job, pretty easy if you’re slightly mechanically inclined. Just pop off the engine cover and intake tubing, then I personally unbolted the wire loom to make it a bit easier to move about. Then its just pulling the coil's and plugs and replacing them. Look for oil build up in your spark plug wells once you have pulled the coil and before you start unscrewing the plug. No good if there happens to be gunk (soot, dirt, heaven forbid a metal shaving) in there. cause when you pull the plug all that fun stuff drains into your cylinder and let me tell you a any bit of debris in a cylinder can prove to be a serious problem and a pain to get out. just soak up anything in there with a paper towel and you should be fine. wouldnt hurt to note which cyliders were getting the oil build up there. May or may not be a problem for you, but worth keeping in mind.
Received 1,486 Likes
on
https://g35driver.com/forums/engine-...ug-change.html
Here is a great DIY, it doesn't look that bad. As far as the plugs, I would choose the best ones considering how long they last and how important they are. Don't skimp on these!
