jwt popcharger help!
Old Apr 25, 2011 | 02:24 AM
thenderson's Avatar
i installed a jwt popcharger and z tube and it sounds great! but it seems like the car doesnt feel like i gained any power at all. i know on these d.e motors intakes dont make much power but it feels like i lost some power. i was talking to a couple buddys and doing some research and it says for these motors cai is best for the motor. just want other opinions on this before i get a cai thankz
Old Apr 25, 2011 | 02:36 AM
Affalterbach's Avatar
reset the ECU, either leave the negative cable unplugged over night or do the pedal combos. try again and see if it feels better.
Old Apr 25, 2011 | 02:50 AM
dukehotty's Avatar
+1.... ECU reset will help but you really shouldn't expect to feel any gains.
Old Apr 25, 2011 | 03:13 AM
DrewLe's Avatar
+2 on the ECU reset.
The Z tube + JWT Pop Charger is the is one of the better mods for enhancing the sound without loosing any power.
For the performance aspect of it, dyno proven, the best is Z tube + stock airbox with K&N drop-in filter for our NA engines.
Old Apr 25, 2011 | 04:58 AM
thenderson's Avatar
thank everyone ill do the ecu reset but just wondering how is resetting the ecu help?
Old Apr 25, 2011 | 06:08 AM
Blue Dream's Avatar
I drove ttrank's car solo
Heat soak......................................it's a b!tch.
CAI will be no better than the pop. Stock box with a quality drop in filter is still your best bet for power but won't give you the sound benefit. Your best 2 choices if you want better sound would be the Stillen or R2C intakes. LOTS of information on this subject in the Intake and Exhaust forum. Spend some time reading through it.
Old Apr 25, 2011 | 06:32 AM
thenderson's Avatar
thankz ill read up on that
Old Apr 27, 2011 | 04:08 PM
anynigma's Avatar
Athens Blue G35 Coupe 6MT
Resetting the ECU just reverts it to the original settings, which if I understand correctly is the most aggressive. Your car will sense the difference in airflow, and adjust accordingly, hopefully netting in a boost in performance, but probably not much with a JWT.
Old Apr 27, 2011 | 10:58 PM
BonBG35's Avatar
popcharger heat soaks and doesnt really even give power unless its high rpms. and CAI will lose power too. save your money and buy TPs or md spacer instead.
Old Apr 29, 2011 | 12:20 AM
thenderson's Avatar
thankz for da help
11bEMT
May 27, 2022 03:13 PM
Video Share
Jan 31, 2017 04:00 PM
bigmike
Sep 17, 2015 01:58 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
CrazyLogic219
Aug 13, 2015 06:40 PM
