billet grill causes honking alarm
Old May 4, 2011 | 05:34 PM
thayamoviete's Avatar
I have an 06 coupe. I have a billet grill, but whenever i put it in, it makes the car's alarm go off at random times, like it starts honking outta nowhere. Why is this? i see other g35 coupes out there with the same grill and they dont have a problem.
Old May 4, 2011 | 06:01 PM
GR6RR's Avatar
Your car has it's own personality. It really doesn't like the mod your trying to fit it with.
Old May 4, 2011 | 06:44 PM
Silencer_0's Avatar
Aren't you the guy that bought Penelope's (revthisbitch) grill? And +1 to the above post, your car is telling you it doesn't want that thing on it.
Old May 4, 2011 | 06:55 PM
walshtj's Avatar
Dude you are going to get really flamed for this thread. Everybody is going to say your car hates it... Id go ahead and delete this thread.
Old May 4, 2011 | 07:02 PM
Silencer_0's Avatar
^ Check out some of his previous threads, he's already been flamed pretty bad in the past, lol.
As for the OP, how do you know it's the grill that's causing the alarm to go off? Also, I thought you switched to the OEM grill a while back? You went back to the billet?
Old May 4, 2011 | 07:06 PM
AreSicks's Avatar
How about you all offer some helpful advise instead of just cluttering the thread. You don't have to like it, it's not your car. He didn't ask for your opinion of how it looked either.
Op: My guess would be that the grill is stopping the hood from sitting flush. There is a hood pin switch integrated into the alarm system so if someone were to pop your hood, the alarm will go off. I would unplug that switch or jumper out the harness for it (not sure how it works - never looked at it close enough), and see if you still had the same issue. You might be able to adjust the switch so it sits higher too.
Old May 4, 2011 | 07:28 PM
Silencer_0's Avatar
^ It was a joke. No one in this thread gave thier opinion of how it looked. And I help people on this forum on a daily basis, thanks.
Check out this quote and thread.
Originally Posted by KPierson
99% of the time false alarms are caused by messed up hood pins. Its really the only sensor that can set the alarm off. You can try disconnecting the hood pin and see if that fixes the problem.
The other sensors are:
Door Pin (one per door, completely isolated from each other)
Trunk pin (I believe it's in the locking mech)
Thats it. Nothing else will set off the alarm. There are no vibration, shock, motion, tilt, glass, or radar sensors on the G stock.
Like I said, I would disconnect the hood pin before anything else and see if that fixes the problem.
Also, adding a Viper alarm would NOT fix this problem, as the OEM alarm would still false trigger and there is no way to disarm the OEM system since it arms every time you lock the vehicle.
https://g35driver.com/forums/audio-v...ml#post1284433
All I did was search for "alarm going off randomly".
Picture Share
Feb 4, 2018 12:41 PM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
g.spot
May 9, 2016 10:54 PM
vQFamily
Sep 30, 2015 01:17 PM
