Sunroof creaks when going to "tilt" position
Old May 5, 2011 | 09:52 PM
AuAltima3.5's Avatar
My sunroof recently started to creak when going to tilt in the last centimeter or two of motion. It doesn't sound good.
I searched, but all I found was to clean/lube the slides. I don't think this will help the tilt motion much. Does anyone know how to lube the tilt slides (if such a thing exists)?
Old May 5, 2011 | 10:25 PM
luisp88's Avatar
this might sound ghetto but i use armor all (the same one i use to clean the dash)
i spray it on a rag and apply it to the rubber seals on the sunroof i wont hear it creak for months
Old May 5, 2011 | 10:27 PM
gary c's Avatar
Easy fix, make sure every inch is clean then wipe off all the mechanism with WD40.
Gary
Old May 5, 2011 | 10:33 PM
Gary
Are you talking about the tracks that go front to back? I will try this tomorrow, provided my bronchitis doesn't kick my ****
I've got white lithium grease. I treat all the rubber seals on my car with gummi pfledge once every month or two, including the sunroof.
Old May 6, 2011 | 12:26 AM
Affalterbach's Avatar
get some silicone lubricant spray or grease, mine did the same thing and it is fine now. Put it on the rubber lining of the sun roof glass and the body.
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
NailBomb
Oct 28, 2015 07:53 AM
dcsbh1
Oct 1, 2015 03:15 PM
