Will a 350Z engine bolt directly into a G35 Coupe
Old Nov 21, 2004 | 01:16 AM
SKYL1NE's Avatar
Will a 350Z engine bolt directly into a G35 Coupe?
Thanks,
AlanL
Old Nov 21, 2004 | 01:23 AM
ducatiguy's Avatar
Premier Dough Slapper
Re: Will a 350Z engine bolt directly into a G35 Co
Yes, they share the same long block...
"See, the problem is that God gives men a brain and a *****, but only enough blood to run one at a time."
Old Nov 21, 2004 | 07:32 AM
g_thirtyfive's Avatar
isnt it the exact same engine?
Old Nov 21, 2004 | 08:01 AM
04G35Coupe's Avatar
they are exactly the same engines.
04 DG G35 coupe 5AT / z-tube / grounding wire gear / Unorthodox SS Pulley Set / next mod Plenum ...
Old Nov 21, 2004 | 10:24 AM
Speedoholic's Avatar
G (enie) FUNK ERA
I think you'll have some problems with the mounting points as they obviously have different engine bays. As long you keep all of the mounting arms, you should be fine.
MY G-ENIE
Old Nov 21, 2004 | 02:06 PM
VinNYCG's Avatar
G SQUAD
yea I agree, the mounting may be a bit different but other than that it should be the same.
Vin
Old Nov 21, 2004 | 03:17 PM
Rudeboy's Avatar
Why would you want to put the same engine in the car? It's the exact same engine just with a different intake and maybe the ecu. other then that it's the same thing.
2004 Skyline 350GT 5AT DG/G Clears,Bats, Now wit Bumps in da back! [img]/w3timages/icons/shocked.gif[/img]
Old Nov 22, 2004 | 11:39 AM
nnkfws333's Avatar
Maybe he needs a new engine and can find plenty more Z engines than G's. I say if you need a new engine, pop in a RB or heck go with an SR! Either way you will have more HP than the stock G.
S13/SR20 SOLD!
DG G35 Coupe
Boost is an addiction *sigh*
Old Nov 22, 2004 | 12:25 PM
iLLG35's Avatar
NY G-Squad G Race Driver
How about a skyline motor swap
Martin
2003.5 BS G35
Nismo Aero/Sport Package
0-60 5.4 - 1/4 Mile 14.16 *GTech* and on 19's!!
Karnicle
Jul 23, 2015 05:08 AM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
