2003 G35 Coupe Electrical Problems
Old May 27, 2011 | 01:25 PM
03XG35's Avatar
Some of you may have seen my thread yesterday about the car not starting. The only way it starts now is if I got a jump.. obviously needs a new battery because when the car wont start the battery light will come on.
When the car is turned on, all the exterior lights work, Hazards, headlights, turn signals, etc.. but some of the intereior lights don't work the roof lights, dash lights and the clock lights work. the lights that don't work are the gear lights, P, N, D, etc...
ALSO the radio works. BUT I can not turn it off and it wont light up so none of the buttons work, to even turn it off or change the station. The only way to turn it off is if the car is off!
Do you think this could be because the battery is drained? I'm buying a new one today.
Old May 27, 2011 | 01:36 PM
herrschaft's Avatar
Are all of the fuses good?
Old May 27, 2011 | 01:38 PM
03XG35's Avatar
I'm not sure if all the fuse spots in the engine compartment are supposed to be filled, but the compartment where you put the fuses into is missing fuses in about 5 or 6 spots.
Old May 27, 2011 | 01:54 PM
03XG35's Avatar
All the fuses that are in there now are good to go though.
Old May 27, 2011 | 02:08 PM
dreamreality's Avatar
yea i would try a new battery first and then replace the fuses if the battery doesn't solve the issue.
Old May 27, 2011 | 02:12 PM
03XG35's Avatar
The drivers side window does not roll up or down either, does anybody know how to reset the motor?
Old May 27, 2011 | 02:15 PM
this might help, although not sure though since you said it doesn't roll up or down?
http://www.infinitihelp.com/diy/gcou..._procedure.htm
Old May 27, 2011 | 02:19 PM
03XG35's Avatar
It won't roll up or down, also the drivers door wont automatically lock.
Old May 27, 2011 | 07:36 PM
dave's Avatar
Our doors don't automatically lock.
Old May 27, 2011 | 07:53 PM
gveng's Avatar
why don't you start by buying a new battery first and then trouble shoot?
TWASkyliner
Feb 8, 2020 08:00 PM
Augy
Steering & Suspension
Sep 8, 2015 12:53 AM
Tom_P
Jul 24, 2015 04:05 PM
Chattzx
Jul 17, 2015 11:23 AM
