Clutch question!
Old May 31, 2011 | 02:43 PM
muddimar's Avatar
Clutch question!
So, I'm fairly certain that my throw out bearing is going bad (Making Noise). I was thinking that instead of just replacing the bearing, maybe I should buy a clutch kit instead and replace everything. My car is a 2006, 62k miles, clutch seems to be slipping a bit. Any recommendations for a clutch kit that isn't overly expensive? Should I only replace the bearing? How much would a shop typically charge for this kind of work? Any thoughts?
Old May 31, 2011 | 03:46 PM
4D05G35's Avatar
Replace it all. I would just go with an OE clutch unless you need the extra clamping force of an aftermarket clutch.
Old Jun 2, 2011 | 03:53 PM
brandon1978's Avatar
My 06 has 58k and the orig clutch/throw out bearing have been making noise for years. I'd replace it if it was slipping, but not just to get rid of the noise.
Old Jun 2, 2011 | 03:56 PM
nghiars's Avatar
is the noise chatter? and does it go away when you press down on the clutch? if so, that is normal and will not go away. Just want you to be sure before you fork out the money for parts and labor.
If you do need to replace it, it'll likely be noisier with an aftermarket clutch/flywheel combo, so i would run with an OEM set up again.
jsimonk
Dec 22, 2023 03:49 PM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
socalg35x
Jul 28, 2015 10:42 AM
