So I got my spark plugs changed today...
Old Jun 12, 2011 | 10:29 AM
BAUSauto's Avatar
Originally Posted by R&D Factory
Here is a DIY Instructions on how to replace the OEM seals on your Nissan VQ engine.
1- THIS IS A SIMPLE HOLE SAW (SIZE 1 7/8 INCH) THAT YOU CAN BUY FROM MOST HARDWARE STORE. WE GOT OURS FROM ACE HARDWARE AND IT WAS $7-11
2- THIS IS HOW YOUR VALVE COVER LOOKS WHEN YOU TAKE IT OFF OF YOUR ENGINE
NOTE PICTURE SHOWN MOST LEFT SPARK PLUG HOLE DRILLED.
3- WARNING “PLEASE DO NOT REMOVE BAFFLE PLATE” WARNING
4- POSITION THE HOLE-SAW CONCENTRIC TO SPARKPLUG HOLE AND DRILL BAFFLE PLATE SLOWLY AND CAREFULLY.
5- YOU WILL ONLY NEED TO DRILL JUST ENOUGH TO DRILL THROUGH THE BAFFLE PLATE (WE CLEANED UP ALL THE DEBRIS TO SHOW YOU CLEAR PICTURE
DRILL ALL 6 POSITIONS AND CLEAN OFF DEBRIS WHEN DONE.
6- NOW YOU WILL BE ABLE TO POP OUT THE OLD O-RING GROMMET OUT OF THE VALVE COVER. PLEASE REPEAT 6 TIMES.
7- THIS IS WHAT IT WOULD LOOK LIKE WITH THE O-RING GROMMET OUT
8- USE BLACK RTV SILICONE ON TOP SIDE OF THE NEW O-RING GROMMET (WE USED CLEAR ON OUR DEMO PICTURE SO YOU CAN SEE BETTER)
9- PLACE THE NEW O-RING GASKET IN TO THE HOLE. NOW YOU ARE READY TO RE-INSTALL YOUR VALVE COVER GASKET TO YOUR ENGINE.
FOR MORE INFO PLEASE CALL R&D FACTORY
- Eric
Old Jun 12, 2011 | 10:31 AM
BAUSauto's Avatar
Call them.. They're
R&D Factory
323.888.8891
www.rndfactory.com
Very cool guys they're local to us! They're huge in the 240 / SR20 scene. This is an awesome offer.
I'm reposting this because their threads in a place where not everyone can view it -.-' lol
- Eric
Old Jun 12, 2011 | 05:15 PM
Imperial1's Avatar
Thanks for the post CarBodyKits!
That does look like a great product, however if my engine is indeed burning oil from the stupid piston rings (as I can't see how 1qt of oil can leak from my cylinder 4 every 900 miles or so) Then even this won't help me.. right?
Old Jun 12, 2011 | 06:50 PM
BAUSauto's Avatar
is there oil on the plug? if there is then you might have a valve cover leak.
OR you have a bad plug and had a misfire this time
also what year is your G.. I'm reading a lot of 03-04s buring a quart per 1k mile now x.x and yeah that would be your piston rings
Old Jun 12, 2011 | 07:01 PM
Imperial1's Avatar
^^ I have an 04 M6 (non rev-up)
There *is* oil on the plug the plug was black lol... only on the plug in cylinder 4... all the rest were fine
I'm going through 1qt every 900 miles though and the guy who changed my plugs is convinced my valve covers are not leaking... so that leaves me with the piston rings being the problem FML.... I guess I can use it as an excuse to rebuild the motor and put some goodies in there since if I just changed the engine I wouldn't be guaranteed that the new engine I put in won't burn oil either .
Old Jun 12, 2011 | 07:06 PM
BAUSauto's Avatar
^ compression test that cylinder (I think some autoparts store rents out that tool, or just pay some local shop to do it) your question will be answered.
- Eric
Old Jun 12, 2011 | 07:07 PM
BAUSauto's Avatar
Take a good picture of your plug and post it up or email me at klumzyee@gmail.com
But black burnt plugs are usually signs of bad A&F or misfire.. at idle do you notice any vibrations?
Old Jun 12, 2011 | 07:08 PM
Imperial1's Avatar
Thanks for the tip! I'll get that done this week hopefully.
BAUSauto's Avatar
if your valve cover is excessively leaking into the spark plug you'll notice the oil on your spark plug socket when you removed it
- Eric
Old Jun 12, 2011 | 07:13 PM
Imperial1's Avatar
I left the plug with the guy that changed it... pretty much the metal coil part of the plug that screws in had oil... and the tip was demolished.... all black and covered in oil/carbon.
The car has 0 vibrations or stuttering and I have no CEL. I did replace all 6 plugs but the guy did tell me that plug will get fouled up again in no time.
Old Jun 13, 2011 | 11:28 AM
JZeezG35's Avatar
it could be the seal around the spark plug tube. I would start there.
Old Jun 13, 2011 | 03:30 PM
BAUSauto's Avatar
I still want to say that you're having a misfire or something if the plug looks like that..
Old Jun 13, 2011 | 05:34 PM
the04coupe's Avatar
Do a compression test .
Old Jun 13, 2011 | 06:33 PM
Jmurray89's Avatar
Originally Posted by CarBodyKits
Call them.. They're
R&D Factory
323.888.8891
www.rndfactory.com
- Eric
I second this. They were very helpful. I called them and ordered the seals and valve gaskets and they had them to me in 3 days (from CA to GA).
Old Jun 13, 2011 | 07:11 PM
  #30
Imperial1's Avatar
I'm going to get a compression/leakdown test done hopefully this week and based on those results I'll go from there.
Thanks for all the help/suggestions guys
mtlruss
Dec 20, 2015 01:51 PM
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
yassy
Aug 9, 2015 07:31 PM
wuppiedog
Aug 7, 2015 11:16 AM
