Passenger Window/Lock switch prob
well my motor went out the other day and i pulled the motor housing apart - shot to heck and back. so i put the new on and it works for maybe 2 secs tops. then the switch housing starts clicking like crazy sometimes when i push either the window up/down or the lock button on the passenger door sometime it hits and will move the window motor and stop midway. i think the switch may be bad???
any thoughts or suggestions. seems ive replaced ever single motor in my car except for the vq35de motor - and if i have to replace it this is whats going down
any and all help is greatly appreciated!
I plugged in my new motor. and the switch would only occasionally activate the motor. once i activate the window switch up or down - the motor would only move mono directionally. regardless of whether or not i moved the switch up or down the motor would only move one way. im sort of at a loss
alright so here’s where im at. im getting full power to the down switch wire. also the ground is good. HOWEVER, the power supply (the red wire) is only getting partial power - as checked with a test light. it wont illuminate fully. any body know where to go from here. im no good at all with wiring and thanks very much for everything thus far.
awesome news. got it fixed and working again so it now rolls up!! hooray! only issue is now it wont auto roll up or roll up when i try to do it from the key hole in the door. anybody got a clue???
Well i pulled out the old motor. bolted up the new. cleaned the contacts on both the driver and passenger switch modules bc i was getting sticky switches on each side. & I’ve found motor reset methods that SHOULD fix the problem - I just havent had the time to try it. but thankfully the window does work again so i can drive it - a week driving my SUV sucked!
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
BradMD_96
Oct 6, 2015 09:31 AM
