Rear Axle Removal?
Jun 19, 2011 | 03:47 PM
Hey guys, I'm gonna fix the axle click this week. can you just remove the bolts bolted to the rear diff to remove the axle or do i have to remove the bolts holding on the bearing too? I know the 32mm has to come off but.... Thanks!!
Reply 0
Jun 19, 2011 | 05:33 PM
Removal of bearing bolts not necessary.
Reply 0
Jun 19, 2011 | 05:49 PM
Correct. Just remove the 32mm nut, it's torqued to 177 ft/lbs so I had to stand on my breaker bar to break it loose, then take out all 6 nuts and bolts off the axle flange. IIRC I had to drop the sway bar as well to snake the axle out of the hub.
All in all it's really easy, maybe a 2 on a 1-10 scale.
Reply 0
Jun 19, 2011 | 07:54 PM
k sweet thanks guys, what did u use for grease?
Reply 0
Jun 19, 2011 | 08:10 PM
Valvoline Synthetic
Reply 0
Jun 20, 2011 | 11:57 AM
just regular motor oil? that worked? could i use royal purple lol?
Reply 0
Jun 20, 2011 | 12:12 PM
No dude, I know they sell oil but they make a synthetic grease too.
Reply 0
Jun 20, 2011 | 12:55 PM
That's what I used^^ and I've had no more click for ~ 12,000 miles since we fixed mine.
Reply 0
Jun 27, 2011 | 04:13 PM
I just did this yesterday, I used a can of valvoline synthetic grease. Basically same as above, I caked it on the axle. Easy job! Actually it got much easier when I remembered u can rotate the axle lol, when I removed the bolts I didnt twist it to get to the ones on top, I jammed my hand in there lol and unbolted them.
Reply 0
