ABS, VDC, and slip lights
Old Jun 21, 2011 | 07:35 PM
TruGame's Avatar
i put 20 inch rims on my G35 coupe with 295/35 rear and 245/30 front and now all the lights or on ( VDC SLIP ABS ) ???? whats going on help me
Old Jun 21, 2011 | 08:04 PM
Kuneff's Avatar
That happened on my car when I went with 19's and some crazy low profile tires.
Old Jun 21, 2011 | 11:58 PM
the_sedan's Avatar
too small of tires or too radical of a difference between front and rear overall diameters. my lights came on and the vdc was activatin when my LR tire blew out and i had to run an oem 17" wheel to get to work lol
Old Jun 22, 2011 | 12:16 AM
herrschaft's Avatar
Your rear tire is too tall. You want the overall diameter of both front and rear tires to be as close as possible.
Use this: http://www.miata.net/garage/tirecalc.html
Old Jun 22, 2011 | 12:21 AM
the_sedan's Avatar
im running 20x8.5/10. had 245/35 and 275/35 with no problems, now im on 225/35 and 245/35 with no problems.
but like /\ said....too big of a difference in diameter
Old Jun 22, 2011 | 12:27 AM
Frankieg35's Avatar
How are u not rubbing like crazy with that rear size?? Lol
Old Jun 22, 2011 | 12:52 AM
WTF??'s Avatar
Shouldve went 295/30 rear and 245/35 front
Old Jun 22, 2011 | 07:09 PM
TruGame's Avatar
so how do i get rid of the lights, i like my tire size and it doesn't rub maybe because i didn't lower it yet.... im thinking i want be able it lower it but its on, how do i get rid of the lights
Old Jun 22, 2011 | 07:21 PM
Blue Dream's Avatar
I drove ttrank's car solo
You don't. The car's computer doesn't like that set up and never will. Only option is to get the diameter of your tires w/in 3% of each other. Sorry I don't have better news for you.
Old Jun 22, 2011 | 08:48 PM
TruGame's Avatar
So if I get 245/35 tires on the front it's should be alright
Old Jun 22, 2011 | 09:02 PM
Blue Dream's Avatar
No that won't work either. 245/35/20 has a diameter of 26.8". Your 295/35/20 is a huge tire and it's diameter is 28.1" or a 4.7% difference which will keep those lights on. If you're dead set on keeping the rear tires as is your best option is to go to a 245/40/20 which is 27.7" tall or a 1.4% difference. All those pretty lights would go away then. Use the tire calculator in the link below to help you determine what would work for you. Just remember the 3% rule.
FWIW I don't think you will be happy in the long run with tires that big and meaty. They will look funny on a G IMHO.
Old Jun 22, 2011 | 09:52 PM
TruGame's Avatar
Thank you every 1 for the help I think I'll just return the tires lol
Old Jun 22, 2011 | 11:14 PM
the_sedan's Avatar
just make sure you hit that "vdc off" button before you take off every time and you should be ok lol
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
JermaineSanders
Aug 18, 2015 08:57 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
