Mysterious rear noise
Old Jul 1, 2011 | 09:41 AM
nogoodname's Avatar
hey, I was wondering if anyone has the same rear noise as my G35 does or has an idea of what it could be. It's a metal clanking noise whenever I go over bumps which can be clearly heard by me and others around me!
It really sounds like thin metal hitting something. Whenever i go over expansion joints, it's only when the rear wheel that goes over it i hear it so that's how I know it's from the rear.
So far, I checked the center and rear exhaust sheilds, those are fine. The cats have been replaced. The catback exhaust has been replaced. Rear sway was removed and that annoying clanking is still there!! So I dont know what to check next!
I also removed stuff out of the trunk....thought it could have been something bouncing around back there but guess not...
Any advice or help is much appreciated!
Old Jul 8, 2011 | 09:01 PM
swoo35's Avatar
I also have this noise, it sounds like creaking in the rear when going over bumps.
Old Aug 7, 2011 | 09:44 PM
nogoodname's Avatar
It ended up being the rear parking brakes. At the bottom of the assembly behind the rotor, there's a piece of metal that got loose. Who would have thought that little piece of metal would be so loud lol.
To test if it's the same noise on ur car, pull (or press) the parking brake just before it clicks while driving around at idle speed. If the noise goes away. You found the problem!
Hope this helps some. It's the known problem for the FX's.
Old Aug 8, 2011 | 10:19 AM
fstasfk_G's Avatar
infiniti's famous axle click =]
rezendvous420
May 31, 2020 01:26 PM
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
ScraggleRock
Aug 11, 2015 10:16 PM
atk08
Jul 30, 2015 03:12 PM
rping
Jul 26, 2015 09:53 PM
