Replace Piston rings or swap entire engine?
Old Apr 4, 2013 | 12:38 PM
  #31
g35nightrider's Avatar
Unhappy
Originally Posted by blAk mAx
look into changing the o-rings that are on the valve covers. you can buy new covers (around $300) or do the $60 fix yourself. you can tell if theyre bad if you have oil in/around your spark plugs
Yeah I believe the mechanic changed those too..I'm not completely sure. Here's what was on the invoice..
  1. Motor Oil <Synthetic>
  2. Oil Filter
  3. Cam seals (4 count)
  4. Valve cover gaskets
  5. Intake gasket set
  6. Timing chain tentioner
  7. Pcv valve
  8. Coolant
  9. Valve stem seals <HP Silicone> (24 count)
  10. BG induction system cleaner treatment
  11. Front Crank seal
Old Apr 4, 2013 | 03:35 PM
  #32
blAk mAx's Avatar
Nope
Old Apr 4, 2013 | 07:25 PM
  #33
HereKittyKitty's Avatar
  2. Oil Filter
  7. Pcv valve
  8. Coolant
I'am no mech. but its an upper engine fix.............full engine re-build should be around 6.5k.
Old Apr 9, 2013 | 02:29 PM
  #34
Wow, that's hefty. I'm getting a few estimates. I'll let you know what comes out of it.
Old Mar 19, 2015 | 12:54 AM
  #35
Exodus5656's Avatar
I have the same OC issue and I have been measuring it overtime and so far I have put 2.5 at over 3500miles. I am thinking about have the cylinder honed and bored a tiny bit so I'm not too far off from stock. Idk exactly how to go about this. I have 94k mi and I use Lucas synthetic additive and I mix 1qt with 4qt mobile full synthetic 10w30 hi mileage. Any advice will help. I am literally flying through plugs and oil.
Old Mar 28, 2015 | 07:39 AM
  #36
Exodus5656's Avatar
So I just rolled over 4k miles and I have topped the oil off with 4qts. I'm changing my oil tomorrow. Any suggestions to fix this?
Old Mar 28, 2015 | 07:41 AM
  #37
Nope! I had an complete engine rebuild, one of the cylinders was oval, car still sucks oil!
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
joedaddy1
Jul 28, 2015 02:58 PM
realtalk21
Jul 20, 2015 09:07 AM
igking
Jul 19, 2015 01:12 AM
Ashton35
Jul 17, 2015 10:11 AM
