Window auto-adjust Problem
Old Jul 9, 2011 | 01:32 AM
tygastyle80's Avatar
I just noticed that my driver side power window is acting up. When I open the door, the window used to lower itself about an inch to avoid hitting the side roof panel when I shut it. But now this auto-adjusting feature is only going down about a quarter inch and is almost hitting the side roof panel when I close it. Once open I can manually push the window down to the level it used to go down to. The passenger window is working fine... Anyone have this issue?
My gf recently left the headlights on and drained the battery. I think this window problem happened after the battery drain. Any help would be appreciated.
Old Jul 9, 2011 | 01:38 AM
Phonggggg's Avatar
i think might be helpful for you.
http://www.infinitihelp.com/diy/gcou..._procedure.htm
Old Jul 9, 2011 | 03:31 PM
hmmm.. so I need to take apart the door. But will a reset solve this issue? The window works fine otherwise...
Old Jul 9, 2011 | 06:20 PM
superchargedg's Avatar
Mine has always dropped about a 1/4 of an inch even when i did the reset with a new motor.
Old Jul 9, 2011 | 10:47 PM
I drove half an hour to a dealership to get this thing fixed and they took a look and told me it was "working properly" despite the fact that it was barely moving down when the door was opened. I said eff that, came home, and took the damn door apart myself. After I got to the window motor, it was getting mad dark outside and i couldnt see **** so I fiddled around with the window controls a little bit, didnt even do the reset and put everything back together again. All of a sudden it's working properly now. Sometimes you gotta take matters into your own hands.
A word of caution to anyone trying to DIY this procedure... Taking everything apart aint too bad, but putting it back together is a real bitch and a half. Mounting the motor and the pulley system back onto the metal frame was a friggin nightmare. The DIY should really mention that....
Old Jul 10, 2011 | 12:39 AM
AuAltima3.5's Avatar
For future reference for myself, after removing the door panel, you have to remove the motor/regulator mounting plate to get to the reset switch? I thought it was just removing the door panel and it would be right there?
Old Jul 10, 2011 | 01:59 PM
After removing the door panel, you can access the reset switch if you remove one of the stickers on the metal frame. I figured this out AFTER the entire door was dissected.
Old Jul 10, 2011 | 03:35 PM
Yeah, I just figured that out too. I just reset mine.
All that damn Jinglish, I was holding the reset the reset button on the way up and was like "WTF!". Figure out you only hold it on the down. Then just roll up and viola.
Old Jul 10, 2011 | 04:33 PM
OBsessed's Avatar
Originally Posted by Phonggggg
Just saw this link but don't know if this is what I need to do. I just installed a new window motor and it's not going up quite far enough, I'm getting wind noise and it's maybe an 1/8" lower than the other window when "fully closed." Will this window reset procedure fix that or do I have another problem? Other than not going up high enough it's working just fine, auto up and down are good and it does come down when I open the door but it's almost necessary, I don't think it would hit the body the way it currently is. I'm confused, any help would be greatly appreciated!
mike730
Jan 12, 2018 04:25 PM
mjfenix
Aug 17, 2017 05:49 AM
leo38cheng
Nov 12, 2015 06:49 PM
cmesidewayz
Sep 29, 2015 09:28 PM
Jnm07
Sep 5, 2015 01:16 AM
