Help!! I think my car is overheat, not sure x(
Since a few days ago it was too damn hot here in SoCal, I started noticing both of my fans were on high probably after 10-15min of driving. I never heard it that loud the 4 years i owned this 04 coupe. Even when my car was idle in the shade for about a few minutes, the fans were still on while it was 75 degree outside.
Today I drove 30 min to LAX, noticed my heat gauge went 3/4 of the way up. Had to slow down for it to idle at mid point
anyone had any idea of what's going on? much appreciate
Check coolant level and bleed out any possible air in the system.
Also it is more normal for the fans to kick on at idle vs. driving down the freeway (at idle there is no airflow).
If it's frequently overheating do not drive it as you can end up with a blown head gasket and warped heads (assuming that is not already what has happened).
Best of Luck!
Jason
Best of Luck!
Jason
I went to check, my coolant level was fine, did not exceed max level. Yea i didn't drive anywhere afterward. gonna bring it to pepboys tmr. Hope it's nothing too serious
...perhaps it's from the new injen cold air intake that I got a few months ago...iono
Thanks guys!
Thanks guys!
Please, try to fix this yourself, or take it to a real shop. You are probably going to regret PB.
Have you ever serviced the cooling system before? Miles?
I suggest a coolant drain, replacing the thermostat. It's a good start. DO NOT forget to bleed. Use the lisle funnel and the FSM.
Gary
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
marsman328
Northern California
Aug 11, 2015 07:29 PM
