Transmission fluid change...at 80k?
Old Dec 24, 2012 | 02:51 AM
  #46
coolkat142's Avatar
I have 110k on my G. Ive been wanting to change my diff fluid for so long but i cant do it myself. Can someone please help me. Does anyone have a garage or lift, there are things i want to check under the car too. can someone please help. I live in md but can drive anywhere bascially.
can anyone help me.
thanks/
Old Dec 24, 2012 | 01:18 PM
  #47
04G35NYC's Avatar
^ Don't do it if you dont have the records its been done before.
Old Dec 24, 2012 | 01:21 PM
  #48
HereKittyKitty's Avatar
Did my diff. and tran. at 65k.
Old Dec 24, 2012 | 04:18 PM
  #49
Darkstar752's Avatar
I really don't understand how keeping old fluid would be beneficial to the transmission, especially in a case where it's shifting slower and feels worse on shifts. If it was me, I would get the fluid exchange done, it will increase lubrication and decrease the amount of heat the system is subjected to. If you're too scared to do that, then just drain and fill to get ~35% of the old fluid out to increase lubrication somewhat.
I know these guys have had shops for 15 years, etc, but our transmissions are beefy and will not be toast at 80k unlike some transmission out of a 1990 Jetta. I don't have a 5AT, but my fluid smelled burnt when I pulled it out at 60k of my 6MT and the shifting felt much nicer afterwards. In the end it's your car, do what you want, but systems fail due to a lack of lubrication, which in turn creates excess heat, neither of which an old fluid is going to provide for you. If I listened to some of these shop owners who've been in business for 30 years, my car would straight up be running like ****.
Old Dec 25, 2012 | 06:42 AM
  #50
coolkat142's Avatar
^ Exactly why i want to change my Diff fluid. Can anyone help me over this weekend. Please.anyone, i am willing to compensate for the help. anyone with tools or a lift.
Old Dec 25, 2012 | 04:42 PM
  #51
AJY's Avatar
AJY
There is a Huge difference between an Auto and Manual transmission. As for the diff and Mt's change it. The diff is super easy just put it on jack stands pop the drain let it out close the drain and fill till the fluid pours out the top close. Simple.
Manual Tranny's don't need the friction to engage like the autos do so changing the fluids out wouldn't hurt anything in a manual.
Again Just my 2c.
Old Dec 25, 2012 | 04:44 PM
  #52
AJY's Avatar
AJY
You only need two Jack stands (or if you're ballsy two scissor jacks) A basic Metric socket set and a basic metric Allen set. I think the trans drain for autos was a 19mm socket though? don't quote me on it. Good luck bud
Old Dec 25, 2012 | 05:14 PM
  #53
devin7632's Avatar
just do a drain and fill
Old Dec 25, 2012 | 08:12 PM
  #54
It's extremely easy man, just DIY. All you need is a ratchet and hex head socket, and then the fluid and fluid pump for filling. If you don't have a lift just use 2x4's, the differential isn't that far back.
http://infinitihelp.com/diy/gcoupe/p...eplacement.php
Old Dec 26, 2012 | 03:56 AM
  #55
coolkat142's Avatar
I want to use a lift though. Just Cause.
Old Dec 26, 2012 | 03:58 AM
  #56
coolkat142's Avatar
Im sure someone has a lift, or know of a DIY garage where you can use one. Arnt there any DIY garages out there anymore, Maryland or Virginia
Old Dec 26, 2012 | 10:48 AM
  #57
Lol good luck with that one then.
g.spot
May 9, 2016 10:54 PM
f22raptor
Mar 18, 2016 08:50 AM
AL8782
Oct 3, 2015 10:26 AM
