When replacing OEMs with aftermarket wheels
Old Jul 21, 2011 | 09:54 AM
Gem352004's Avatar
I was thinking of putting new 18's or 19's on my car. Do I have to make any adjustments when doing so?
I currently have the 2004 18' 7-spoke oem rims.
Old Jul 21, 2011 | 10:12 AM
gmotion04's Avatar
depends one if your going for stretched/flushed. or just a stock oem spec replacement. you might have to roll your fenders to make a wider tire fit.run low profile tires if your too flush to avoid screwing up the fender. a lot of factors play into this.
Old Jul 21, 2011 | 10:30 AM
Affalterbach's Avatar
you can put 20s on it stock height with no problem. if you drop it 2 inches or so you might have to roll the rear fenders.
Old Jul 21, 2011 | 10:35 AM
Gem352004's Avatar
Heres the spec's of the new wheels:
Wheel Style - Rota P45R
Wheel Diameter (Inches) - 18"
Wheel Width (Inches) - 9.5"
PCD Bolt Pattern - 5x114.3
Offset - +20mm
...Hub Bore - 73mm
w/ 275/35zR18 Tires
Heres the of my current wheels:
Size: 18" x 8"
Style: ALLOY WHEEL, FRONT, 18 X 8, 7 SPOKE, FRONT
Size: 18" x 8"
Style: ALLOY WHEEL, REAR, 18 X 8, 7 SPOKE, REAR
Front tires-Hankook ventrus R18 225/45z
Rear tires- Hankook ventrus R18 245/45z
Old Jul 21, 2011 | 11:00 AM
Gem352004's Avatar
Also, do I have to balance them?
Old Jul 21, 2011 | 11:32 AM
jvm0685's Avatar
your wheels wil be tucked a bit with that offset but you should be able to run those specs no prob. only thing im not sure about is if youre gonna have any vdc issues if youre running those tire sizes front and back...but i'm sure someone with better knowledge will chime in
Old Jul 21, 2011 | 12:24 PM
gary c's Avatar
Those wheel sizes will work but I'd feel better if the fronts were 18X8's and you shouldn't run larger than 255s. Yes, they'll need to be balanced, that's cheap insurance....
Gary
Old Jul 21, 2011 | 02:24 PM
Gem352004's Avatar
Do you think those size wheels would interfere with the VDC?
Old Jul 21, 2011 | 03:06 PM
nghiars's Avatar
no they wont.^^
bTanz
Oct 15, 2015 02:31 PM
rping
Jul 26, 2015 09:53 PM
BlackGee35
Jul 23, 2015 01:36 PM
