Ideling to high? Check engine code PO507
Old Aug 2, 2011 | 02:25 PM
Gem352004's Avatar
Hello,
Last weekend I added an intake system in my car. Everything was fine until the next morning when I started my car the check engine light was on. I check the code, PO507, which is idle system control issue. I definitely hear my engine idling a lot higher than usual. Would the intake I added be causing this? Or would it be something else causing this. I still have a warranty on the car but I’m nervous now that I added that mod it will disqualify the warranty. Thanks.
Old Aug 2, 2011 | 03:07 PM
MADtotheA's Avatar
Do an ecu reset then do an idle relearn. Search for it.
Old Aug 2, 2011 | 06:52 PM
TruGame's Avatar
same thing happen to me when i put my cold air intake and throttle body spacer, i just took off the negative for half hour the reconnected and never saw it again
Muski_G
Dec 1, 2023 11:11 AM
Jay 21
Aug 5, 2015 04:53 PM
Roblee22
Jul 30, 2015 12:11 PM
ClwMike
Jul 23, 2015 12:55 PM
Jadenkid22
Jul 14, 2015 12:33 AM
