Question about my exhaust and it hanging low...
Old Aug 4, 2011 | 11:04 AM
viventi's Avatar
I noticed this on my car a while ago, and it didn't really bother me at first but it is now...the left exhaust pipe is hanging a lot lower than the right.
Is this a common thing? I could've sworn I saw another G coupe with the exhaust hanging uneven like this before. Any way to fix it?
27467380.jpg?t=1312470224
Old Aug 4, 2011 | 11:21 AM
Mark2K8's Avatar
I have something similar. My left exhaust is longer than my right one lol.
Old Aug 4, 2011 | 11:50 AM
AustinG35's Avatar
I have had the same problem with both my OEM stock tip hanging lower on the left side and the aftermarket exhaust tip did the same thing. Seems to be somewhat common, as I looked at the tips on several of our forum cars when we met last Friday night, 8 of the 10 had a slightly noticeably lower left tip.
Old Aug 4, 2011 | 11:52 AM
AustinG35's Avatar
Originally Posted by kidtronix
Common issue. As the it ages, the exhaust hanger sags, causing this. The best thing you can do is perform exhaust hanger surgery to remedy the low-hanging symptom or think of the happier, more youthful days of the past when your exhaust was more upright and didnt have any performance issues.
Or buy a true dual exhaust with a canister on each side and never worry about sag again.
How would one fix the hanger? Do you mean to 'bend' it upwards or something else?
Old Aug 4, 2011 | 12:16 PM
Xet's Avatar
Xet
Check the hanger. It is more likely the rubber piece going out than anything bending with the metal bracket. I'm sure you could buy a replacement for them somewhere...
Old Aug 4, 2011 | 12:21 PM
viventi's Avatar
I figured it was a hanger, but I honestly don't know too much about actually going about fixing it lol.
I've entertained the fact of getting a new exhaust anyway, but i really don't want to change how the car sounds. plus, i doubt it'd be much of a performance gain, if at all.
Old Aug 4, 2011 | 12:54 PM
Xet's Avatar
Xet
Most exhausts reuse the rubber piece attaching from the exhaust to car, a new exhaust wouldn't solve your problem if it is the rubber piece causing the droop.
Old Aug 4, 2011 | 02:17 PM
herrschaft's Avatar
You should be able to buy that rubber peice at any auto store. They are relatively cheap and replacing it can be done by anyone, though it was a PITA for me. If you look under the car where the exhaust piping mounts to the car, you will see the rubber mounts everyone is talking about.
Old Aug 4, 2011 | 02:31 PM
fstasfk_G's Avatar
now u have a reason to purchase a new exhaust lol
Old Sep 29, 2011 | 07:25 PM
AuAltima3.5's Avatar
So any advice for replacing the hangers on the muffler? I am about to order some new OEM pieces and wonder if you have some advice on how to do it? I looked under the car and it's tight under there.
Old Sep 29, 2011 | 07:51 PM
Xet's Avatar
Xet
Taking the rear of the exhaust with the piece attached and then going at it while it is off is the easiest way imo. Depending on its condition it may put up a nice fight so be ready.
Old Sep 29, 2011 | 08:05 PM
gary c's Avatar
Easy fix, buy a OE rubber hanger from Nissan the next time you get an oil change swap em out. Might be a good idea to use a little WD40 to make the job easier....more slip/slide.
Gary
Old Sep 30, 2011 | 08:45 PM
I just bought the four rear rubber bushing hangers, plus a new midpipe to muffler gasket.
I plan on fixing this minor issue in the next week or two, possibly with pics.
Thanks for the input Gary. I am hoping I can somehow just undo the top part of the two rear upper hangers after unbolting the muffler. I only have jackstands so it should be really fun.
Muski_G
Dec 1, 2023 11:11 AM
Shizzmaster2k
Engine - Exhaust
11
Sep 2, 2015 04:09 PM
gatorglaze
Intake & Exhaust
Aug 17, 2015 02:16 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
