Sound cuts out when playing CDs, but not when playing radio. Headunit problem?
Old Aug 15, 2011 | 12:22 PM
n00b's Avatar
When I play CDs in my 2004 coupe the sound occasionally cuts out when I hit a bump, or the left speaker will stop playing and sound will only come from the right speaker. It does NOT do this when I have the radio on, and only when playing CDs. Is this a headunit problem?
Also, if it is a headunit problem, what new sets of headunits do you recommend? I personally like the OEM one, but am open to new suggestions. Thanks
Old Aug 15, 2011 | 04:54 PM
CharlesHubular's Avatar
Its a common problem Most people replace the head unit with an aftermarket DVD screen but you would need a new double-din dash to fit it. Just do a little research and you'll understand.
Mine does the same thing and I used to drive around with a speaker out for days until I learned that all it needs is a swift smack to the side of the dash under the steering wheel works like a charm.
Old Aug 15, 2011 | 07:08 PM
R10T_x's Avatar
yea i had the same problem but i was still under warranty so the dealer replaced it
Old Aug 16, 2011 | 01:20 AM
n00b's Avatar
Thank you, the swift smack worked GREAT, it's playing perfectly normal now. I hope it lasts for a while so I don't have to shell out money to get it fixed. Thank you again.
chinee
Jun 10, 2024 07:48 PM
Frostbite91
Aug 20, 2015 07:20 PM
chinee
Aug 8, 2015 10:11 AM
atk08
Jul 30, 2015 03:12 PM
