cracked compression rod bushings?
Old Aug 21, 2011 | 02:03 AM
thesparky007's Avatar
I went to the stealership for an oil change (only cuz i had a coupon) and they told me my compression rod bushings are cracking and need to be replaced... i was quoted some 900$ for it....
Im currently out of warranty but I know there was a tsb out for it saying to only replace just the bushings?
How do the service bulletins work? are the dealership required to address the problems even the car is our of warranty?
What should I do? should i buy aftermarket ones and have them replaced at a mechanic?
Old Aug 21, 2011 | 03:41 AM
datbeans's Avatar
I am in the same boat. I will soon be purchasing
http://www.z1motorsports.com/350_g35...oducts_id=5193 <--these and installing them.
Even if i was to pay a trusty mechanic to install the bushing, my total will still be under $900
Old Aug 21, 2011 | 11:22 AM
jibberjabbers's Avatar
How can labor be $800?
Old Aug 21, 2011 | 11:27 AM
gary c's Avatar
This is a perfect example why we don't go to Infiniti for service. My favorite come back to Infiniti service managers is, "Do I have STUPID written on my forehead?" Buy the bushings on line and find an independent brake/alignment shop in your area and have them pressed in....NBFD!
Gary
Old Aug 21, 2011 | 11:49 AM
04G35NYC's Avatar
All i can do is laugh at the price. I can't stand dealers with overprices prices. Max it should cost $200 with parts and labor.
Old Aug 22, 2011 | 06:50 PM
Ok will buy separately and have it installed...
Now about the tsb.. are the dealerships required to fix the problem mentioned in tsbs? Or are they just references to fix
Old Aug 22, 2011 | 07:15 PM
gary c's Avatar
$800 to replace bushing....=o(
Call the thieves at the stealership and ask them if it's covered, myself I'd rather pay than have them touch my coupe as long as cost is minimal....
Gary
Old Aug 23, 2011 | 03:17 PM
brandon1978's Avatar
are the dealerships required to fix the problem mentioned in tsbs? Or are they just references to fix?
Nope, just a reference.
Old Sep 23, 2011 | 11:22 AM
sybertel's Avatar
Just had my compression rod bushings (CRB) replaced in San Diego at Kearny Mesa Infiniti (KMI). They charged about $450 for the entire job including parts. It took them about 1 hour to perform this repair service.
Car is an 03 6mt coupe with about 42K mi on it. KMI claimed that the bushings deteriorate over time and that it is not mileage related. I got the bushings back and can not see any cracks even with a magnifying glass. (Possibly the "cracks" show up better when the bushing is on the car.)
My car did not have any symptoms of worn out bushings commonly described in previous posts. However the loud front end road noise seems noticeably quieter since the CRB replacement. Have any others noticed this improvement? My tyres are original.
Nissan Part number for bushing is 54570-AC70A. Note that there might be a date of manufacture on these just above the part number. The date appears to be yr/mo/day format. Assuming that Infiniti is correct and these parts deteriorate over time, it might be best to demand newly manufactured CRB's. One of the ones I bought was dated June 1, 11; however the other was dated Dec. 24, 10; which is nearly a year old already. Had I known this I might have insisted on newly manufactured CRB's.
Old Sep 25, 2011 | 10:41 PM
monster520's Avatar
bought commpression rod bushings for 50 bucks had them pressed in for 20$. I just had the remove and install myself. Entire procees was pretty easy and alot cheaper than dealer.
Old Sep 29, 2011 | 08:30 PM
sybertel's Avatar
From the various posts above, it seems that Infiniti has decided that the cost will be at least $450 no matter how quickly they can get the job done. I guess we are supposed to be paying for experience more than actual shop rate costs.
Monster520's approach is very appealing and if I keep this car for another 6 years I may be attempted to use it.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
DRG35R
Jan 31, 2016 07:14 AM
prinny
Nov 22, 2015 11:07 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
AL8782
Oct 3, 2015 10:26 AM
