radio too loud
Old Sep 5, 2011 | 10:43 PM
2MUCHG4U's Avatar
radio too loud
so earlier today i hit a pot hole. it was the worst pot hole ive ever encountered. it took a piece of my soul when my g hit it. but once it was all iver my radio started playing too loud. having my radio on 6 is like having it on 20-22. its way to loud and has a lot of static to it. very upset right now please help......
Old Sep 5, 2011 | 11:18 PM
partyman66's Avatar
I'd try disconnecting the battery for a night and then reconnect it in the morning. That's a start.
Old Sep 5, 2011 | 11:28 PM
coupetech's Avatar
go hit the pot hole again, should go back to normal.
seriously u may have jarred something in the audio unit or the amp, try knocking on everything see if it straightens out.
Old Sep 5, 2011 | 11:38 PM
ThatOneDude's Avatar
There's this little *** thingy and usually if you twist it counter-clockwise, it should lower the volume. Best of luck! n_n
Sorry, just teasing. Since it's playing at 3x the volume, wouldn't keeping it on 2 or 3 have it around 7 or 12?
Old Sep 6, 2011 | 12:16 PM
bommy261's Avatar
Do you have an amplifier? You may have knocked the sensitivity **** on it and it went to a higher setting. Try reducing it until you do not hear noise even at the highest volume (on your headunit).
Old Sep 16, 2011 | 07:47 PM
2MUCHG4U's Avatar
sorry for the late reply....very late reply. i work a lot!
but same night i tried taking out the amp and checking to see if there was anything wrong and i could not find anything. gave up for the night.
next morning it fixed itself......bad ***, BUT
for some reason, when i listen to a cd, if i hit even the smallest bump on the road all the audio goes to the right side of the car.......only with a cd. i have to change discs or take it out and put it back in to get it back to normal. what can it be???
Old Sep 16, 2011 | 08:15 PM
SG Blaze's Avatar
I had the exact same issue with the radio going out on one side of the car(left side) when listening to a CD and fluctuation in the level of sound coming from the speakers. I took it to the dealer and they claimed I needed a new Head-unit. I hear that issues of this nature are quite a common occurrence in Bose equipped cars(not sure if yours is). Luckily I have a warranty so they replaced the head unit and the issue was fixed.
Hope this helps
Old Sep 17, 2011 | 10:30 AM
rimshaker's Avatar
Glad i purchased my extended warranty recently. Replacing audio/nav components costs an arm and maybe a leg too.
Old Sep 17, 2011 | 11:12 AM
R10T_x's Avatar
Hope this helps
+100000 same thing happened to me did the sane thing as sgblaze
Marlin84
Apr 1, 2020 12:52 PM
Learned Hand
Oct 1, 2015 09:02 AM
alinero718
Sep 27, 2015 09:35 PM
1Typhoon
Sep 25, 2015 08:45 PM
