Half Synthetic or Full Synthetic for Oil change?
Old Dec 14, 2004 | 09:03 AM
Pratik's Avatar
Moderator
At a Nissan dealership, they have both types of synthetic. I was going to go with 5W-30 but I'd need the full synthetic right? What exactly is put into the half? I'm assuming its half synthetic and half regular oil? I should say that I'm at 10K miles now and have dino'ed all the way to fully pass the so called break-in. I know we all have differing opinions on it. I'm almost positive I should be going with the fully synthetic but just to confirm here. I live in DC and Mobil 5W-30 seems the best bet. Yes, I know Amsoil and Redline are better but the Mobil is also easily available.
Maybe someone can inform me here.
Thanks.
Old Dec 14, 2004 | 12:51 PM
avs007's Avatar
If you want a blended synthetic, it's better if you blend it yourself.(ie, put in half dino-juice and half synthetic)
The "pre-blended" synthetics, only contain something like 5-15% synthetic, from what I remember. I've been using full synthetic Mobile-1 since the very first oil change at 3750.
Old Dec 14, 2004 | 12:56 PM
Pratik's Avatar
Moderator
Yeah thats the thing. At my dealership they recommend to not go with synthetic but just their regular oil which they say is 5W-30 but i'm not sure what that means. They offer Mobil-1 there. Obviously they just want me to come back more often and I'd probably wait 5K miles between changes.
Old Dec 14, 2004 | 01:11 PM
CadBill's Avatar
I intend to switch to Mobil 1 synthetic. What is the current thoughts on min & max miles per oil change ?
Old Dec 14, 2004 | 01:13 PM
Pratik's Avatar
Moderator
IMO Mobil 1 says you can go 10K miles in between changes but I'd say 5-6K miles and you should be okay. This depends on also your climate and also your driving habits.
Old Dec 14, 2004 | 02:30 PM
mrmcderm's Avatar
BMW service interval on Mobil1 is 15k IIRC.
If you only have 10k on your car, just switch over to full synth. You may notice a little extra consumption with the first batch, but thats normal. The only time you should slowly introduce it is if you have a higher mileage car (60k+).
Old Dec 14, 2004 | 03:13 PM
sen_jen's Avatar
Meatshake Enterprise
yups, i switched to mobil 1 when i reached 10k miles. i still switch every 3- 3700 miles too. i'm in hawaii and it gets heated so i use 5w-30.
mrmcderm's Avatar
oh yeah, forgot to mention that. BMW may recommend 15k, Mobil may recommend 10, but I change every 5
Old Dec 14, 2004 | 03:17 PM
Msedanman's Avatar
O.F. Administrator
I've been using fully synthetic Castrol Syntec (5W30) since first oil change.
Old Dec 14, 2004 | 04:08 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
While still within the warrantee period the specified interval still applies
regardless of which type you use.
Th611
Oct 27, 2015 03:48 PM
Ednica87
Sep 5, 2015 02:59 AM
derres
Aug 28, 2015 03:27 PM
wuppiedog
Aug 7, 2015 11:16 AM
ClwMike
Jul 23, 2015 12:55 PM
