Transmission flush vs drain confused
Old Sep 21, 2011 | 09:54 PM
leoverte's Avatar
Originally Posted by Nismo G
If you have a auto tranny i would be EXTREMELY careful with what fluid you put in there. You can get it from the dealership for around $10.00 a quart. We have replaced numerous transmissions due to people getting fluid changed at pep boys etc and then having failure, actually did one this week. Manual transmission fluid you will be fine with as long as it is the correct weight.
bieng that i have an auto with 95k, i planned on acutally doin a drain and fill...is this correct for me?!? Or should i do a flush?!?! sounds like i should just perform a drain and fill from this thread...what particular fluid or is any nissian dealership auto tranny fluid good?!?! Sorry to bug you nismo g, but seemed like you know what your talking bout..
Old Sep 22, 2011 | 01:46 AM
10splaya22's Avatar
AUTO=flush
MANUAL=drain and fill
Therefore you will do a flush, its better to let a mechanic do it with their machine. On manuals, its almost like changing your oil (drain the fluid out and fill with new fluid)
Old Sep 26, 2011 | 07:59 AM
Nismo G's Avatar
sorry for the late response, but matic S is what fluid you should be purchasing from the dealer. It is around 10-11 a quart. In all reality there isn't a huge difference between the drain + fill and a flush. Depends on your comfort level pretty much. If you aren't having any problems with your transmission then a drain + fill is going to be sufficient (6-7 quarts).
g.spot
May 9, 2016 10:54 PM
f22raptor
Mar 18, 2016 08:50 AM
Row2k
Drivetrain
Dec 27, 2015 04:08 PM
Rose M
Oct 12, 2015 10:00 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
