New alternator still not charging HELP!
Old Oct 3, 2011 | 01:14 PM
longcoo817's Avatar
Angry New alternator still not charging HELP!
My battery light and brake light came on when it started raining so i limped it back home thank god. I went and bought a new alternator and replaced it now itll charge sometimes and sometimes it wont. But when it does charge the battery light is still on but sometimes it turns off. I have removed the new alternator and got it checked and it passed all 3 test at oriellys have check all the fuse on the driver side kick panel and the fuses under the hood. The Fusible link is still good what els should i look for?
Old Oct 3, 2011 | 06:12 PM
gary c's Avatar
Check your battery cables, make sure they are tight and in good condition? Is your drivebelt in good condition? If it's dried/worn out and got wet it may be slipping. That's the first two things I'd check....Gary
Old Oct 3, 2011 | 08:23 PM
vegaszx10's Avatar
If you have a multi meter just start tracing the alt wire. Then check the connection make sure theres no corrosion. Then if everything is good check for resistance in the wires.
Old Oct 3, 2011 | 09:37 PM
ajm216's Avatar
How old is your battery?
Old Oct 3, 2011 | 11:52 PM
longcoo817's Avatar
battery is 3 months old...
longcoo817's Avatar
no corrosion on any wire just replace it with a 0 gauge as well as the ground wire
Old Oct 4, 2011 | 06:28 AM
ajm216's Avatar
Have your battery tested so that you can remove that from the troubleshooting process.
A faulty battery can make strange things happen.
Old Oct 4, 2011 | 07:57 AM
Nismo G's Avatar
Agreed. People come into the dealership with crazy things happening to their car electrical wise and then it turns out to be the battery. I would have it checked!
Old May 16, 2014 | 02:51 PM
James86's Avatar
where is the alt fuse i cant find a pic of it anywhere
BradMD_96
Oct 6, 2015 09:31 AM
