Tried ECU reset, now car only clicks
Old Oct 9, 2011 | 11:20 AM
Franky's Avatar
Unhappy Tried ECU reset, now car only clicks
So I just bought an 06 coupe, am having problems with VDC so I tried an ECU reset using the gas pedal method. After I hold the pedal down for 10 seconds, the CEL blinks, release for about 10 seconds, but when I re-press the accelerator, the light stops blinking. I'm pretty sure it is still supposed to blink, but I've tried a ton of times, with and without a watch, but I cannot keep that light blinking. Now, anytime I try to start my car, it only clicks. I've got the battery disconnected now. Please help!
Old Oct 9, 2011 | 11:25 AM
faiz23's Avatar
Leave battery disconnected for 1hr and hold the brakes down for 30 seconds when you disconnect. Let car sit and then hook terminals back up. Are you sure your battery is in good condition or is it the original battery. With the car sitting at the dealer the battery might have lost charge so you will need to jump it. If it still just clicks when you jump then you might have an issue with starter solenoid...
Old Oct 9, 2011 | 12:01 PM
Franky's Avatar
The battery is in good condition. I drove it from NJ to Ohio and had to sleep in it one night. So, even when the engine was cold, it still started fine. I didn't try to start it this morning before trying the reset, but I will try leaving the battery disconnected. Hope this helps because I've still got other problems to fix with it.
Old Oct 9, 2011 | 12:41 PM
walshtj's Avatar
Yeah if you leave your battery disconnected for a few hours it will reset the ecu also.. If it still isnt turning over it could be an issue with the battery or alternator.
Old Oct 9, 2011 | 10:45 PM
Franky's Avatar
It was the battery. Tried charging it, but it didn't seem to be holding a charge. Got a new one, started right up. Now I have to figure out my other problem.
Old Oct 9, 2011 | 10:48 PM
faiz23's Avatar
What other problems are you talking about the slip/vdc/brake light. Check your brake pads and how much life you have left along with fluid levels for clutch and brake.
Old Oct 10, 2011 | 08:12 AM
Franky's Avatar
I see you found my other thread about the dash lights, so I'll bring this into that topic.
Old Oct 10, 2011 | 09:46 AM
gary c's Avatar
I had the same issue with my battery, everything worked but the battery didn't have enough juice to turn over the starter....just that clicking sound you described. It's important that you don't leave your battery disconnected for more than an hour or two max, your ECU will begin to forget why it's there.
Gary
Hasanbaloch
Feb 29, 2024 08:45 PM
mike730
Jan 12, 2018 04:25 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
stay_tuned
Jul 21, 2015 07:09 PM
kenthung
Jul 21, 2015 05:56 AM
