spray paint rims
Old Oct 14, 2011 | 09:38 AM
bluranver6's Avatar
Thanks guys i think im gonna get some rattle can and paint my factory's until i can buy some new rims
im gonna do silver and clear on top of that
Old Oct 14, 2011 | 10:05 AM
Larzo's Avatar
i would use some bug and tar remover first, get all that S*** off first... wash with soap and water, dry them, (if u have a air comp that will make life easier), then sand the clear coat off of the entire wheel... wash again then paint... But 2 things bro ...1) since im sure your not taking the tires off get a deck of cards and put them in between the tire and your rim so you dont paint you tire... And 2) take you TIME... the trick is for it not to look like a$$ smal coats then finish with about 2 or 3 light coats of clear... Just my opinion
Old Oct 14, 2011 | 10:12 AM
ThatOneDude's Avatar
If you're going to sand down the clear, don't bother washing it so hardcore before that.
Old Oct 14, 2011 | 11:28 AM
Larzo's Avatar
Werd^^^
Old Oct 14, 2011 | 11:44 AM
G35SedanGrn's Avatar
I painted mine & always get asked if thr powder coated, my trick is prep each wheel. just prep takes me about 2-3 hours, I sand with 400grit making sure to get every edge then use bondo spot putty for all curb marks and junk then sand again with 400 grit then scuff with 800 grit then wash it off really good & let it dry, then put a deck of cards around the edge & paint 2 coats of primer, 3 coats of paint and 2 coats of clear wet sanding between coats and then waiting a couple days and waxing/compounding the last coat of clear since you don't wetsand the last coat.
Old Oct 14, 2011 | 10:06 PM
bluranver6's Avatar
thanks for all the info and tips i bet they will turn out nice im gonna take my time to paint them thanks again
Old Oct 14, 2011 | 10:28 PM
If it's not too much trouble, share the outcome, even if it's bad. Explain to us what you think you did wrong, or just explain your process. It'll be good for people who may want to try it later.
Best of luck, and have fun with it!
Old Oct 15, 2011 | 04:32 PM
gerbilunit's Avatar
good tips here. like g35sedangrn said, prep really improves the outcome of your work. it makes a world of difference.
Old Oct 15, 2011 | 08:40 PM
Cleanmachineskc's Avatar
Can you powder coat the oem 19s? I've heard baking the forged rims is bad idea. Any truth to tha
Old Oct 16, 2011 | 12:07 AM
4D05G35's Avatar
Yes you can powdercoat them. Plently of people have done that.
Old Oct 17, 2011 | 11:10 PM
G35AndTGOD's Avatar
I wouldn't do it
Old Oct 20, 2011 | 12:41 AM
rich250x's Avatar
they can look good if you know what you're doing
Old Oct 20, 2011 | 11:13 AM
paky786's Avatar
I'm looking forward on painting my OEM 18" Gunmetal
Old Oct 20, 2011 | 11:33 AM
cameronb's Avatar
powder coating will hold up better and last longer... mine are currently getting powder coated gunmetal.... something like $200.
To prep the wheels the correct way, sand them, paint them (barrels included), and clear coat them... you are looking at a little over $100. spare the extra $100 and have them powder coated imo.
Old Oct 20, 2011 | 11:39 AM
  #30
R10T_x's Avatar
ive seen some spray paint rims that look great and other that look like sh*t i believe its all in the prep work just my .02
