help,,car wont start! :/ 2005 G35 coupe
Old Oct 24, 2011 | 02:15 AM
nelbarr's Avatar
Exclamation help,,car wont start! :/ 2005 G35 coupe
Hi everyone, I am new to this forum and just encountered a problem with my 05 g35 coupe, manual transmission. I decided to change the spark plugs and before i started I followed a DIY spark plug threads and I went ahead and removed the battery cables negative and positive first then went ahead and removed the bolts to get to the spark plugs. I finished putting in the spark plugs and all bolts and went ahead and plugged the battery terminals but my car wont start now! :/ my battery is good because the radio, interior lights work fine, can anyone please help me out? I would really appreciate this so much, thanks.
Old Oct 24, 2011 | 02:44 AM
bythabay's Avatar
Is it cranking? Does it almost start? Could you describe the symptoms in a bit more detail please?
Old Oct 24, 2011 | 02:49 AM
nelbarr's Avatar
no crank at all, only lights, radio, and interior lights work.
would pushing the car and try to start it off 2nd gear work?
Old Oct 24, 2011 | 02:55 AM
bythabay's Avatar
Assuming all you did was replace the spark plugs I would say you either shorted something out or the battery is drained. Try googling "how to diagnose a no-start." Did you disconnect the negative battery cable first? I once saw a guy short out his whole electrical system because he connected the positive and negative terminals of the battery - blew out his voltage regulator in the alternator too - had to replace the alternator.
Old Oct 24, 2011 | 02:56 AM
bythabay's Avatar
also double check that you reconnected all the grounding bolts
Old Oct 24, 2011 | 03:29 AM
nelbarr's Avatar
I am pretty sure the battery is still good because the car was running good 30 min prior to not starting and the lights work fine..no start up or no crank.
I removed the negative cable first then i removed the positive afterwards...at the end when putting battery together, I put the negative then positive cable.
Old Oct 24, 2011 | 05:47 AM
Metalp3n's Avatar
Old Oct 24, 2011 | 09:10 AM
azn pho life's Avatar
maybe you just did a simple mistake of forgetting to connect the coil pack to the harness. lol
Old Oct 24, 2011 | 09:22 AM
wbama387's Avatar
Thats what i was first thinking but the car would still turn over if that was the case.
Old Oct 24, 2011 | 09:27 AM
wbama387's Avatar
Make sure your ground cable on the battery is good and tight. I have seen interior work but wont start car because there is not a good ground.
Old Oct 24, 2011 | 11:25 AM
smoovarrowhead's Avatar
check voltage of the battery first, if in the 12's you should be good. clean the battery posts and cables and reconnect.
Old Oct 24, 2011 | 01:53 PM
nelbarr's Avatar
I dont remember removing a ground cable from the battery but i will check that out, thanks.
Old Oct 24, 2011 | 01:56 PM
nelbarr's Avatar
Yes, I am thinking possibly battery low voltage just because it has an AAA battery intact and looks dusty and possibly old (that is how the dealership sold the car)which ive never seen such battery like this before..
Old Oct 24, 2011 | 06:43 PM
nelbarr's Avatar
Fuses and the ground wire is perfectly fine, and the car still wont start up..:/
Old Oct 24, 2011 | 07:16 PM
superchargedg's Avatar
If all this happened after you disconnected the battery there is a bad connection at the battery post's positve or negative its one of them
