Wet passenger Floor
Old Oct 31, 2011 | 07:44 PM
avion's Avatar
Wet passenger Floor
After driving 4 hours with the AC on on low, I noticed when I got home the passenger floor was soaked! Also I was driving in the hard rain for most of the trip. This is a 05 Coupe with only 20K miles. Is it the AC drain condensation problem or some sort of rain leak? Any ideas?
Old Oct 31, 2011 | 10:32 PM
partyman66's Avatar
I would guess rain leak. You'd better dry that rug out pretty soon with a blow dryer before the car starts to get a mildewy smell. Check for leaks in your windshield, sunroof, firewall and door window seals by spraying them down with a hose while someone else sits inside the car and looks for signs of water seeping in.
If you find the leak, you can probably plug it up with some sort of water-proof silicone sealant.
Old Oct 31, 2011 | 10:33 PM
Project's Avatar
Mine leaks right now through the wiring harness where it goes into the car from someone running the edfc wires through there. Thats where i would look.
Old Nov 1, 2011 | 07:18 PM
avion's Avatar
Well I'm doing some troubleshooting. I removed the mats and replace it with cut out paper bags. I washed the car and saw the paper bag under the air conditioner wet. Then I opened the hood and sprayed water in the little screen area behind the battery. (Fresh Air Intake?) Now the water was pouring in. This weekend I'll remove the plastic screen and see if it the wire gromet is not seating right after running the Sub's power wire or a possible seal or drain that is plugged with trash. I'll keep you posted. Thanks for the idea.
Old Nov 1, 2011 | 07:28 PM
superchargedg's Avatar
You could also have a clogged drain hose from the evaporater assembly.Put the car up on a lift and locate the hose/pipe and use a long screw driver and put it in the tube...just dont stand in the path of the drain or you will get soaked.
Old Nov 1, 2011 | 08:46 PM
Eskimo10's Avatar
Dude, I've got the same issue. I'm assuming mine is from the amp wires I ran. Which is where I'm going to start looking when I tear into my car this weekend. I'll report back when I narrow it down.
Old Nov 1, 2011 | 08:50 PM
Project's Avatar
Yup i just seen mine when i left it out overnight in the dew....guess they really arent sealed to good and mines leaking off a thin i imagine that would be your problem with a ground wire
Old Nov 2, 2011 | 07:19 PM
avion's Avatar
Water Leak Solved!!! Gromet behind battery was loose.
Leak Solved!!! Gromet behind battery was loose. After installing my Sub, I had to the power wire and routed the wire through the fat gromet with all the main wire bundle. The Gromet is hell trying to get perfect back in place. So what would happen every time you washed the car or rain, water would find it's way to the gromet area and leak in. So what I did today is to reinstalled it as best as I could then surounded the gromet where it meets the body of the car with clear silicone sealent. Frankly the placement of that groment is very poor design. Just a leak waiting to happen
Hope this helps others.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
BradMD_96
Oct 6, 2015 09:31 AM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
