Problem when filling gas tank
Old Apr 15, 2012 | 07:45 AM
  #31
81gSKy's Avatar
Originally Posted by saltyload
I'm not sure if it's the gas pump itself or my gas tank, but the gas pump stopped when my tank was at 3/4 full. I tried it again and got the same result. First time it happened to me and I've used this pump before. Anyone ever have this issue/problem?
Originally Posted by snowrider13
There's a post about this. It only happen to me at a shell station. All others is fine.
Originally Posted by redpearl99
always happens to me at shell stations
WOW... It happens to me at most Shell station as well, but it seems though BP fills up fine. I've only filled up with BP the other day as I wasn't too sure about BP fuels, they seem to be alright... I have always only used Shell for my 350GT/G35 Coupe, as a trusty R&D fuel and back with motorsport involvement. Mobil would have been an option, but there are no more Mobil stations in Oz anymore. Reading quickly through the posts, it seems that it's a temperamental problem? Why does it happen more so with Shell station pumps than others?
Old Nov 15, 2017 | 12:02 AM
  #32
Bill Campos's Avatar
Smile G35 Filling up On Gas Problem, Happens To Me ALL the Time, I just keep trying
Old Jan 21, 2018 | 04:13 PM
  #33
CHIEN05G35x's Avatar
Is there a recall on this? I was trying to fill up my tank and all of sudden gas pours out and spills on my pants smh. And when I start up my car the gauge only says 3/4
Old Jan 21, 2018 | 04:50 PM
  #34
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Two problems happened, yes one is the evaporative vent clog that the letter went out for, check out this thread:
https://g35driver.com/forums/g35-sed...ty-letter.html
The second problem was the overflow valve on the fueling nozzle didn't trip, you should inform the station clerk which pump nozzle it was so he can get it fixed.
You should ALWAYS stand off to the side when filling your vehicle, if you need to turn it off from an overflow condition you can do it at the pump itself by depressing the switch plate where you put the nozzle when finished, I learned the hard way too...
Old Jan 21, 2018 | 09:49 PM
  #35
I got the 1st Gen sedans, an 05 G35x would it matter? Ill contact Infiniti tomorrow see whats up
Old Jan 21, 2018 | 10:14 PM
  #36
cleric670's Avatar
BANNED!!!
I think it can affect all years if G35's but I'm not totally sure.
Old Feb 16, 2018 | 01:58 PM
  #37
lalomarquez13's Avatar
Originally Posted by EnerOnE
I noticed this if I didn't park the car correctly. As in too close to the pump and not right in front of it. I would have to manually have to hole the nozzle and re click the trigger multiple times until I would just give up. Now, that I have been parking at a good distance I haven't had this problem. I'm not sure if it was the pumps or what but pumping gas for me is not a pain anymore....*knock on wood*
This worked for me as well! I was going crazy trying to figure this out.
mtlruss
Dec 20, 2015 01:51 PM
Patrick Bovee
Sep 4, 2015 11:57 AM
Jroc2017
Aug 16, 2015 07:16 PM
brian_z
Jul 22, 2015 09:19 PM
ZacDesu
Jul 14, 2015 11:13 PM
