Y pipe, what does it dO
Old Dec 15, 2011 | 02:40 PM
TruGame's Avatar
I was thinking about replacing my Y pipe with a just pipe no restrictions but I was wondering what does the Y pipe do anyway
Old Dec 15, 2011 | 03:15 PM
.cakestar's Avatar
lol?
Old Dec 15, 2011 | 03:23 PM
Roh's Avatar
Roh
"with a just pipe no restrictions" ? lool
Old Dec 15, 2011 | 07:32 PM
dphillips2011's Avatar
you can achieve the same effect by blocking off one of the outlets on your stock y-pipe. that way all the exahsut goes through one side. it makes somewhere around 12whp/tq.
Old Dec 15, 2011 | 07:33 PM
Shanes_G's Avatar
bull ish^
Old Dec 15, 2011 | 08:43 PM
gary c's Avatar
Buying an aftermarket y-pipe is a waste of your $$ since the restriction in your exhaust system is in the OE cats. Either replace them with BERK'S HFCs or MotorDynes Art-pipes, hp gains are 6 to 8 rwhp.
Gary
Old Dec 15, 2011 | 08:53 PM
Jaxon1023's Avatar
Or go with a Q pipe!
Old Dec 15, 2011 | 10:14 PM
4D05G35's Avatar
A Y-pipe is just as it sounds, it's a pipe that has two inlets and splits into one outlet (on these cars). Most vehicles with either a V6 or V8 engine (or any V-series configuration) use them to combine the exhaust gasses from the left bank and right bank of the engine into one singe exhast pipe. It is used as a collector. A quick online search would give you a little insight, I recommend doing so before picking aftermarket parts. You really shouldn't be replacing parts, if you have no idea what they do.
Most people do exhaust mods for sound, as there is no real worthwile performance gains to be seen on these cars.
Old Dec 15, 2011 | 10:23 PM
R10T_x's Avatar
Lol +1
Old Dec 15, 2011 | 10:25 PM
Jaxon1023's Avatar
Originally Posted by 4D05G35
A Y-pipe is just as it sounds, it's a pipe that has one inlet and splits into two outlets. Most vehicles with either a V6 or V8 engine (or any V-series configuration) use them to combine the exhaust gasses from the left bank and right bank of the engine into one singe exhast pipe. It is used as a collector. A quick online search would give you a little insight, I recommend doing so before picking aftermarket parts. You really shouldn't be replacing parts, if you have no idea what they do.
Most people do exhaust mods for sound, as there is no real worthwile performance gains to be seen.
Actually it has two inlets and one outlet lol
Old Dec 15, 2011 | 10:47 PM
04WhiTe_G_Coupe's Avatar
I replaced my stock cats with BERK's and the difference is like night and day plus it sounds better. If you plan on replacing your stock exhaust from the cats back it wouldn't make any sense to waste your money on just a Y pipe anyways, as a cat-back exhaust would replace this. Forget the Y pipe and invest in HFC's or the ART pipes.
Old Dec 16, 2011 | 12:26 AM
4D05G35's Avatar
Actually if you want to get specific, a Y-pipe is non-directional. It can be used as a collector/combiner or distributor/splitter. But for the sake of the argument, yes I transposed that portion of my reply, which is apparent by the rest of my post. Thank you for catching that, I will go correct that now..
Old Dec 16, 2011 | 08:48 AM
Jaxon1023's Avatar
As I should have said in our vehicles it has two inlets and one outlet lol
Old Dec 16, 2011 | 10:05 AM
jarvo's Avatar
It asks, y pipe?
Old Dec 16, 2011 | 10:20 AM
ThatOneDude's Avatar
x-pipes ftw
Video Share
Jan 31, 2017 04:00 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
9tray turbo
Sep 29, 2015 10:22 PM
