G throwing error code
Old Dec 26, 2011 | 08:26 PM
VeRDE35's Avatar
Within the last 4 months I replaced my cam shaft sensor and now again I am having the same symptoms where my car will turn off and vdc and slip will come on. When I took it to get the error code it threw p1564 the ascd steering switch. Any one encounter this problem and if so how did they fix it?
Old Jul 7, 2014 | 07:45 PM
dae's Avatar
dae
Did you ever get this fixed (P1564)? My car is doing the EXACT same thing (i replaced cam sensor today and the dash lights went off but im still getting the steering wheel one and cant find ANYTHING on this...)
Thanks man!
Old Jul 9, 2014 | 08:07 AM
infinitidude's Avatar
Alright guys I have replaced a bunch of these on Infiniti vehicles. You will have to replace the steering wheel switches to fix this. One or more of the functions on the switches are not working or you could have a bad spiral cable also. You will have to look at all of the functions on a data monitor to verify 100%. Most of the time it has been because coke or something got splashed on the switch,not that this is the case for you guys. ASCD stands for automatic speed control device which is the cruise control. The switches will definitely cause a ses light. Hope this helps guys.
Old Apr 16, 2018 | 08:18 AM
Retjami's Avatar
I just got this on my used 2006 G35X.... will it pass inspection with this code? is it safe to drive and can I just let it go or do I need to fix it
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
Learned Hand
Oct 1, 2015 09:02 AM
Detailed Image
Sep 28, 2015 07:04 AM
vamarris
Sep 26, 2015 12:56 PM
