install after market player while still keeping oem bose system
Old Jan 5, 2012 | 04:49 PM
EDGAR's Avatar
Originally Posted by mercuris
I use this to make the cover since it have the same curve as the oem
I meant this lid, what kinda of lid is this?^^^^^
Old Jan 6, 2012 | 11:09 AM
mercuris's Avatar
lol I found this at my local supermarket it is normally ppl use to store biscuits. cakes. fruits etc
Old Jan 6, 2012 | 11:11 AM
mercuris's Avatar
Originally Posted by SAMzG35
do you have a thread when you were doing this install?
not really. wat details do u need?
Old Jan 6, 2012 | 12:41 PM
MUMM RA's Avatar
Would this work for those of us that don't have the bose system with the tape deck? I'm really interested in this.
Old Jan 6, 2012 | 02:31 PM
SAMzG35's Avatar
G35
just more over all info on how this was done, which harness was used, how it was connected exactly.which HU, Im installing a double din in few days JVC KW-NT3 and wondering if its a good idea to have something like that also added since i like the look of the OEM Navi
Old Jan 8, 2012 | 03:37 AM
srtr's Avatar
wow
Old Jan 8, 2012 | 09:09 AM
mercuris's Avatar
it will, even though it is not bose system but u still have the tape in right, the worst part is just that the diagram for the tape in is defferent.
Old Jan 8, 2012 | 11:04 AM
mercuris's Avatar
i will try to explain step by step
after u've taken take this out
1st remove the cd changer n the cassette radio(becareful there are 2 ribbons dun broke them)
(if u dun want to use ur oem radio system dun remove the cassette radio n skip step 3,5,6)
2nd cut off the marking in the photo
3rd make the fooling switch and the aux in, 2 wires for fooling switch, 3 wire for aux in
http://my350z.com/forum/audio-and-vi...p-guide-5.html
fooling switch is to tell the radio that there is a cassete in it to make it function
aux in i connect it with 2 rca male left & right(white & red) so u can directly plug they into the aftermarket player later
4th install the aftermarket player
5th connect the rca to front left n right output
6th find a place to install ur fooling switch(in my case i dun smoke so i install it in my ashtray)
as my player's usb slot is too close to the cover(if i plug pendrive in, the cover can't be closed) so i have extended it to my ashtray as well
6th making sure everything is connected properly get everything checked, install the hu back to ur car. complete!
(u can make the cover afterward)
Jusseth
Sep 13, 2020 12:25 PM
EnCr1pt3d
Jul 8, 2019 02:48 PM
mjfenix
Aug 17, 2017 05:49 AM
