MY G is making a loug engine noise (YouTube video included)
If you don't have AAA already, it's worth it to get it now, since it will probably be cheaper to buy a AAA membership and then have the car towed, than to pay to tow the car the whole way without AAA. Having AAA also gives you like a $75 discount on your auto insurance every year(at least my insurance company does), which pays for the membership cost in its own right, even if you don't use any of their services during that year.
First ever VQ diesel conversion!
Maybe when you took it in to get your oil changed at the stealership, they hooked you up with a bio-diesel conversion. On your next visit to Mcdonalds, ask for a jug of used fryer oil and fill her up, maybe the noise will go away, jk. I'm wondering if it could be an exhaust leak, possibly a cracked manifold, sounds scary enough to to want to drive it. If your oil was black with 2k left until your next change then maybe you should start doing your own oil changes, seems to me like they might be skipping your filter . Sub'd for results and good luck.
Originally Posted by crazynuts16
sometimes it may seem like the noise is coming from the engine are but it could be from somewhere else, just try using a long screwdriver and see if you can get a bit more specific about the noise?
good luck though!
good luck though!
Originally Posted by icekewl
it sounds like a lifter/seal on the top end.. had a vehicle that made that same noise after being started and run without any oil..
Originally Posted by partyman66
You don't have to have it towed to a AAA recommended shop, if you use AAA to tow the car. I was just recommending using the AAA network to tow the car (if you have AAA), as they'll tow you for the first 5 miles or so free, and then you only have to pay some mileage fee for the extra miles. It's a lot cheaper than paying straight-up for a tow out of pocket.
MY problem was I'm terrible at gauging the oil on these cards because my previous car was a Toyota where the dip stick was basically vertical and easy to read, as opposed to G's that are on a terrible 60 degree angle causing messy readings.
I was also worried about the CAMSHAFT censor which i replaced myself last month.. symptoms of it malfunctioning again (VDC and SLIP lights on + spuddering) but the mechanic cleared all those errors with his diagnostic hookup..
Currently car is running very smooth, mechanic said sounds great... really good thing i didn't drive it too much in that condition...
Total cost of all the work from my local new mechanic: $56.60 all incl.
This post definitely steered me in the right direction, thanks everyone.
Holy smokes!@# No oil?!@#
Do you check the oil level regularly, or was the oil recently changed?
When I took delivery of the car, one of the things I checked was the oil level. It read about 3mm below the fully full mark after sitting outside for a bit. This gives me a reasonable frame of reference to monitor future oil use/consumption. You should check your oil at least every other fillup or more often if you have an oil use issues.
prada.robot (01-11-2012)
it was recently changed 2.3k ago... every other fillup is good advice.. and maybe randomly in between... i never want to hear that sound again lol..
thanks for the advice!
Thats not good... running the car with that low oil most likely could have caused some serious damage to your engine. You need to check the oil every couple weeks since youre probably burning oil. Wait until the car sits level for a few hours before checking, its not hard to look at a dipstick
the angle of the stick has nothing to do with the reading...you never checked it..you ran the engine dry...you now think your problem is solved. ha....you now have major wear on rod and crank bearings...you have not yet begun to see your future problems
Since this is my weekend car, and I don't race it.. hopefully it will be alright for the next few years.
Thanks for the advice.
Thaaa_king
07-18-2015 05:56 PM
