Spacer and gps info
Old Jan 11, 2012 | 10:07 PM
one2nite's Avatar
Spacer and gps info
Hi guys,
I will be pickup up my 2004 g35 coupe tmr, just have a few questions
1- Whats a good spacer size for the 18's without rubbing? 20mm? Any pictures
2- Is the oem gps an easy install? or its more complex
I will post pics this week for sure!
Thanks!
Old Jan 11, 2012 | 10:36 PM
Jhambor's Avatar
The spacers depends on how much, if any, of a drop you have. If you're running stock suspension...you shouldn't have to worry about rubbing at any size. I'd probably go with 25 or 30mm front and rear in that case.
Old Jan 11, 2012 | 11:54 PM
fchdx's Avatar
Installing an OEM gps onto a car that did not come with one will be a long and tedious process. Possible, yes, but not practical. You would have to do a lot of rewiring and wire splicing because the wire harness in non-navi G's are different than ones that came with navi. I would highly recommend looking into aftermarket double din head units with gps's instead.
Old Jan 12, 2012 | 12:01 AM
one2nite's Avatar
Perfect thanks
Old Jan 12, 2012 | 12:59 AM
fchdx's Avatar
Hope to see the pics soon!
Old Jan 12, 2012 | 09:10 AM
one2nite's Avatar
For sure within a few days
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
