5MM Spacer question
Old Jan 13, 2012 | 03:18 PM
NATH_19's Avatar
5MM Spacer question
I searched but found no answer...
Would I need to have extended studs if I add a 5MM spacer to the back ?
Thanks !!
Old Jan 13, 2012 | 06:52 PM
HYDRUS's Avatar
Not really. 5mm is pretty small but if your **** about things like that and want to be EXTRA safe then yeah i would get them lol
Old Jan 13, 2012 | 07:54 PM
Xet's Avatar
Xet
I think most people recommend extended over like 3mm...
Old Jan 14, 2012 | 12:48 AM
Silencer_0's Avatar
^ That's usually what I've heard too.
Old Jan 14, 2012 | 12:50 AM
Frankieg35's Avatar
Na u don't need extended studs with 5mm.. anything over that I would run extended studs..
Old Jan 14, 2012 | 01:36 AM
NATH_19's Avatar
thanks guys !!
Ill probably get the 10mm ...
Old Jan 14, 2012 | 01:39 AM
NATH_19's Avatar
BTW... who here has a 10mm that I can borrow to test fit...
I just dont want to buy a 10mm then find out that I'll be rubbing..
I am local soal and will drive to your spot just to test fit..plssss
Old Jan 14, 2012 | 02:28 AM
Xet's Avatar
Xet
Try posting in the socal section, might have better luck there. And what are your wheels, settings, and offsets? 5mm vs 10mm is a pretty decent difference
Old Jan 14, 2012 | 07:36 AM
4D05G35's Avatar
You wont be able to tighten the lug nuts at all with a 10mm so keep that in mind before you meet up with someone for a test fit.
jsimonk
Dec 22, 2023 03:49 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
