Steering Wheel Noise
Old Jan 30, 2012 | 07:57 AM
JiHouse's Avatar
Hi,
Last night I started hearing a weird noise whenever I turned the steering wheel. Almost like a screech.
It even happens when the car isn't moving.
Does anyone know a good idea of what the cause is?
Thanks.
Old Jan 30, 2012 | 10:02 AM
partyman66's Avatar
You need to change or tighten the belts in the engine bay. If I remember correctly, there are 2 on our cars... one for the Power Steering/Air Conditioner, and one for the Alternator. They should be changed every 3 to 5 years depending on how much you drive.
Old Jan 30, 2012 | 10:11 AM
JiHouse's Avatar
Thanks a lot!
I'll try it out.
Old Jan 31, 2012 | 12:03 AM
RedBaronK's Avatar
Also check on the power steering fluid levels.. when its low it can make sounds cause of the stress on the pump
Old Jan 31, 2012 | 12:17 AM
icekewl's Avatar
Ball joint issue
Old Jan 31, 2012 | 12:18 AM
JiHouse's Avatar
I did check the power steering fluid. Its basically at the max.
I went to two mechanics today.
He said the passenger side ball joint or something like that is broken and showed it to me.
He called infiniti for a quote on the price in front of me, yelled on the phone as if he's going for an oscar, and told me the part costs $550. He wants $970 for everything including labor.
The second mechanic said the problem was the same thing that the first guy said.
He offered part + labor for $320...
Old Jan 31, 2012 | 04:57 AM
Blue Dream's Avatar
I drove ttrank's car solo
Sounds like they are quoting you a price to replace the entire steering knuckle, or at least the first guy is. You can buy just the ball joint (~ $60 on ebay) and have the old one pressed out and the new one pressed in. Will be a lot cheaper that way.
jsimonk
Dec 22, 2023 03:49 PM
rping
Jul 26, 2015 09:53 PM
Karnicle
Jul 23, 2015 05:08 AM
tehmoonrulz
Jul 19, 2015 10:44 PM
