Changing Oil
Old Apr 26, 2003 | 03:17 PM
Carlos3186's Avatar
Re: Changing Oil
from what i have been hearing people seem to like mobil 1. I tihnk it is a pritty good oil but i dont reallly know to much about it. I am doing what ever the dealer tells me to do. I am getting them for free so they can do what ever the hell they want at the dealer. But mobil sounds like your best bet
Old Apr 26, 2003 | 04:46 PM
bigel's Avatar
Re: Changing Oil
Mobil 1 is a great synthetic oil. However, since the owner's manual states that Infiniti reccomends mineral based oils, I am sticking with my tried and true Pennzoil.
Old Apr 26, 2003 | 04:51 PM
AntRock's Avatar
Re: Changing Oil
i use regular castrol GTX 10w-30. the manual says to use petroleum based oils only. plus sythetic is overrated and overpriced especially if you are going to be changing your oil every 3k miles. actually i am breaking the rules just a bit the manual says use 5w-30!
Old Apr 26, 2003 | 05:27 PM
bigel's Avatar
Re: Changing Oil
In the summer you'll be fine with the 10W-30, and as long as it doesn't get below 20 degrees often in the winter where you live, it should be ok.
Old Apr 27, 2003 | 02:46 AM
Zeromus's Avatar
Re: Changing Oil
Bigel,
I had the service department put Mobil 1 in my car during its first service and they didn't make a comment on this....will synthetic hurt my engine since the owner's manual says mineral based oils? Damaging an engine this expensive would not be a good thing...
Old Apr 27, 2003 | 02:47 AM
Sloneek's Avatar
Re: Changing Oil
Penzoil is a piece of [censored] and so is castrol. Mobil is ok but Valvoline will always be number one... Thats right I said it.
Quick Robin... TO THE BATMOBILE.
Old Apr 27, 2003 | 11:56 AM
Mike_Tx's Avatar
Re: Changing Oil
Been a lot of discussion regarding Nissan recommendations. I have the Dec 02 6MT Coupe manual which says "mineral based oils recommended". Went to my 96 Maxima (5 spd) which has 130K miles on Mobil 1 - that manual says "mineral based or synthetic oils may be used... Do not mix mineral based and synthetic type oils in the engine at the same time"
I have converted the rear end and the trans to Red Line and will go to Mobil 1 after 7500 - 10000 miles - making sure rings are seated.
JoeMac
Aug 20, 2015 10:17 AM
yassy
Aug 9, 2015 07:31 PM
ghost_g35
Aug 7, 2015 10:31 AM
ClwMike
Jul 23, 2015 12:55 PM
