Should I avoid a 2006 g35 coupe becuse of the oil consumption issues?
Feb 23, 2012 | 12:01 AM
Will Infiniti do anything to fix it? Just how bad is it, if I change every 3k miles am I good?
Reply 0
Feb 23, 2012 | 12:04 AM
5AT btw
Reply 0
Feb 23, 2012 | 12:09 AM
5at's don't have the problem...it's the 6mt's that do
Reply 0
Feb 23, 2012 | 12:11 AM
Ah okay thanks I don't wanna start a new thread but I noticed the 2006 I'm going to buy the headlights loook like ****. My dad has The same year and they look real good. Should I try a product on them or replace the whole thing? I wouldn't mind after market lights depending on the price. What is an approximate minimum it would cost me?
Reply 0
Feb 23, 2012 | 12:13 AM
not worth the price of new ones, you can wet sand them and they'll look like new...search around the forum a bit regarding that
Reply 0
unless that specific one is having a leak then you should definitely turn away
Reply 0
Feb 23, 2012 | 12:15 AM
Just put catrol synthetic 0w-30 european formula
My 07 rev-up was consuming oil BAD, I started putting in that stuff and it has consumer not a drop and I been on that stuff about 9 mouths close to 4 oil changes
Reply 0
Feb 23, 2012 | 12:20 AM
If I wanted after market headlights kinda like BMWs have, is that replacing just The bulb or the whole housing? How much should I expect to spend ?
Reply 0
Feb 23, 2012 | 12:21 AM
Where do i find this stuff? How can I tell its european formula? and what intervals are you changing at
Reply 0
Feb 23, 2012 | 12:22 AM
What is rev up? Was yours auto?
Reply 0
Feb 23, 2012 | 12:23 AM
I usually get my oil changes from Walmart, usually the $30 oil change...is that bad? I know they use brand name oil I think penzoil or something.
What kind of oil should I put in this once I buy my car next week? Is Walmarts $30 oil changes sufficient?
Reply 0
Feb 23, 2012 | 12:32 AM
Quote: What is rev up? Was yours auto?
Rev-ups are 05-07 6mt, they have a few extra things that other gs dont, like dual valve timing, Infiniti marketed them at 298hp, while the nons were marketed at 280hp I think
Reply 0
Feb 23, 2012 | 12:36 AM
Quote: Rev-ups are 05-07 6mt, they have a few extra things that other gs dont, like dual valve timing, Infiniti marketed them at 298hp, while the nons were marketed at 280hp I think
Thanks for The info. I saw rev up always mentioned but never figured out what it meant
Reply 0
Feb 23, 2012 | 12:37 AM
ive read not all 05s have them just a few??
Reply 0
Feb 23, 2012 | 01:50 AM
Quote: ive read not all 05s have them just a few??
Just the 6mt 05-06 sedans and 6mt 05-07 coupes... read the whole thread
Reply 0
