Shudder/shaking at idle..
Old Mar 19, 2012 | 06:33 PM
DigitalMaxz's Avatar
Hey guys..
Wanted to see some opinions about this problem I'm having.
This is for a 2006 G35 Coupe with 69,000 kms (43,000 miles). I've owned this car for 2.5 years and leave the car parked in the garage during winters, drove it around once every 2 weeks when there's no snow, didnt treat it with fuel stabilizer this year. I'm also due for an oil change at 70,000kms, but i'm at 69,300km. And, I think it was done in August 2011 when I had 63,179km.
We've got an early spring in Canada this year, so I took it out last week. I was in line for a car wash and I turn on and off my engine every 10mins or so about 4 times, during the 3rd start up the engine started to sputter a bit from turning off and on, I guess it was dumb of me.
After that, I started to notice a slight vibration/shudder/shaking on my seat/steering wheel and door, as if it was choking abit. It isnt very strong, but I can most definitely feel it. I noticed that my idle rpm when warm and with no a/c starts at 950-900 and slowly goes down to 850-800.
Did I mess something up by turning it on and off 4-5 times in 50mins?
Could it be.. Throttle body cleaning? Vacuum leak? Air filter? Oil change?
Any inputs, suggestions are welcome.
Thanks
Old Mar 19, 2012 | 06:50 PM
william747400's Avatar
You probably didn't mess it up by turning it on and off if it's just that one time.
Try some fuel injector cleaner, clean the throttle body, and check out the air filter to see if it's dirty.
Also take a look at the spark plugs maybe.
Old Mar 19, 2012 | 06:56 PM
That's G's Avatar
+1...good place to start
Old Mar 19, 2012 | 07:15 PM
diablo_cc's Avatar
Starting it infrequently that many times (depending on how long you let it run for) could have just introduced too much fuel into the cylinders and wasn't getting burned off, so the sputtering might have been a reaction to a pre-mature flood. This is a novice observation though.
Old Mar 20, 2012 | 06:08 PM
I'll get those done on Thursday.
I went to get something at the store today, parked and came out, cranked the engine and it didnt start... but it started right after i cranked it again.. I really hope nothing bad's happening.
Diablo: if it is indeed excess fuel in the cylinders, would it burn off eventually?
Old Mar 20, 2012 | 08:31 PM
diablo_cc's Avatar
It should, unless the issue is not as simple as I stated in the aforementioned post.
Old Mar 20, 2012 | 08:58 PM
saywat?'s Avatar
have u ever checked ur spark plug cylinders for oil leak?
Old May 29, 2014 | 10:17 AM
Got my air filter and throttle body cleaned. Ran fine afterwards...
Thanks guys!
Severian596
V36 Brakes, Suspension, Wheels & Tires
12
Mar 28, 2011 05:22 PM
shdowflare
Archived Sales
Mar 3, 2010 10:14 PM
Fiveseven
Intake & Exhaust
Apr 20, 2006 01:54 AM
boost21psi
Dec 11, 2004 01:45 AM
