Brake Pads
Old Mar 28, 2012 | 09:13 PM
g35sleeper123's Avatar
check out project mu
Old Mar 29, 2012 | 02:25 PM
acee's Avatar
Addict
Originally Posted by gary c
This....^....is NOT the bed in process HAWK recommends and it's wrong!....SEARCH bed in process!
Ace you won't have brake fade with the HAWK HPS pads nor will you have the brake dust like the OE pads. If you're having someone install the pads, also have them replace your old brake fluid....cheap insurance your calipers will stay healthy.
Gary
ok ill check it out. definately will take the advice into consideration of changing my brake fluid. thanks.
Originally Posted by TheBigG
I've had them in for a few thousand miles. The stopping power has been more than adequate and I've not seen much brake dust. Honestly not a bad pad for 33 dollars. If I had to do it again I'd go right back and get the same pads. If they wear quicker than OEM ones I'll go buy another set and still be at less than the price the stealership wanted for OEM pads.
yeah i went to the dealership for oem price i was quoted 62 and 59 for front and rear, a guy there gave me a discount idk if thats a good price.
Originally Posted by CantDieLS
^^ that was the bed in process that came in the box of my EBC yellowstuff. Thats why i said "for ebc's..."
^^ Hawk HPS pads provided the best performance I have personally felt on a car. But they squeal the most as well. That was my only complaint.
yeah maybe they both use a different type of bedding process, although a memeber did tell me to do what you described if i went the ebc pad route. still looking to go with the best pad : (
ok. never heard of them but will do.
Old Mar 29, 2012 | 11:06 PM
TheBigG's Avatar
Ace thats actually not a bad dealership price. I was quoted 79 at Nissan for OEM pads. Buy whats in your budget. If you can afford good brake pads buy them, if you cant stick with OEM or something that people have had good experiences with. If your budget is lower than stick with an OEM spec brake pad like the Duralast
Old Mar 29, 2012 | 11:16 PM
acee's Avatar
Addict
oh yeah you had duralast right braking power was good? i have ebc rotors in the front will i feel some difference 33 dollars for a set isnt bad at all, its not like i track my car plus ill be on coilovers soon.
JOKER's Avatar
CLUB MODERATOR
Most of the information found on this site is opinions rather than facts. So you have to be very careful filtering those out and base your decision on facts instead of opinions.
One fact that you will find anywhere is that ceramic pads offer bad cold braking and need to be used with rotors that are designed for ceramic pads.
One of the mistakes most people make is install ceramic pads on rotors that are not designed for ceramic pads. As the result, pads end up eating away at the rotors much faster that regular pads would and you develop vibration sooner than you would with regular pads.
So if you going to spend money to purchase high temp ceramic pads, get equivalent rotors to use them to a full potential.
Old Mar 30, 2012 | 06:33 PM
mario12688's Avatar
Brakes
How do you know if the rotors you plan on buying are rated for ceramic pads? Im looking at the Brembo W0133-1722247 drilled. TIA.
Old Mar 30, 2012 | 11:57 PM
JOKER's Avatar
CLUB MODERATOR
All manufactures have different classes of rotors. Some street, some track, some raising.
So if you are purchasing performance pads, you must purchase performance rotors.
IMO it never hurts to go a step higher on the rotor. Rotor is the one that is taking all of the abuse from pad.
Most slotted and drilled rotors are higher performance that just simple ones.
If you not planning to do any serious tracking with your car, I would stay away from drilled rotors. They will give you little to no benefit at normal driving, but they can crack between holes. Slotted is the best option for everyday driving.
Old Mar 31, 2012 | 12:00 AM
acee's Avatar
Addict
i have slotted ebc rotors in my front i think im going to go with duralast pads according to my budget suggested by theBigG
Old Mar 31, 2012 | 11:06 AM
mario12688's Avatar
I've always been under the impression that drilled rosters were ok for a DD and slotted rotors were for track use only. This is due to the fact that under heavy breaking and race conditions pads become hazed. A gloss or sheen forms under the high temp braking lessening the friction between pad and rotor. The slot acts like a blade "shaving" a thin layer off the pads continuously thus keeping the friction coefficient at its highest. But, this shortens the life of your pads. They can also be usefull in wet braking conditions. The holes in drilled Rotors are used for cooling. Plus the drilled ones look cooler in my opinion. LMN what y'all think...
Old Mar 31, 2012 | 11:10 AM
mario12688's Avatar
Brakes
Ive been using dura last pads for years there's nothing wrong with that. They also make a ceramic version. $48.00 a set.
Old Mar 31, 2012 | 11:29 AM
JOKER's Avatar
CLUB MODERATOR
http://www.g20.net/forum/showpost.ph...00&postcount=1
Old Apr 1, 2012 | 04:32 PM
mario12688's Avatar
^great link
KruZZe
Feb 27, 2023 05:04 PM
BradMD_96
Oct 6, 2015 09:31 AM
Gabe83714
Oct 6, 2015 06:40 AM
alinero718
Sep 27, 2015 09:35 PM
