HELP!! I am confused on 06 headlight swap, mid project
Old Apr 29, 2012 | 02:28 PM
bnorris85's Avatar
Hello, I hope I am just really dumb, but why doesn't my new headlight have the silver coard to plug into the ballast?
I have searched for like 20 minutes and everyone says its just plug and play
Old Apr 29, 2012 | 02:31 PM
takaG35's Avatar
You have to snake that out of your old headlights and snake it back into the new projectors.
I had the same question when I did mine. Once you do that, you'll say...wow
Old Apr 29, 2012 | 02:33 PM
whatsnext's Avatar
havent ever tried the conversion but thats the igniter if not there i guess you could just pull out of old headlights and put in new one
Old Apr 29, 2012 | 02:43 PM
bnorris85's Avatar
So i have to remove this? How I dont wanna break it
Old Apr 29, 2012 | 02:44 PM
whatsnext's Avatar
yep unplug the yellow wire and you can twist that and pull it off then pull it out getting it in new one is the hard part
Old Apr 29, 2012 | 02:47 PM
bnorris85's Avatar
Thank you, now that yellow wire isnt on the new one...problem?
Old Apr 29, 2012 | 03:05 PM
whatsnext's Avatar
from what i undderstand that wires kinda like a ground to stop interference you should be fine with out it when i took my headlights out i disconnected the yellow wire while there where on and didnt affect anything.
Old Apr 29, 2012 | 03:09 PM
bnorris85's Avatar
ill swap it out, i figured it was a ground
Old Apr 29, 2012 | 04:12 PM
itisallg's Avatar
im guessing your new 06 lights are not OEM? it should be a direct swap of BALLASTS ONLY. There should be no need to transfer any type of wiring at all.
Old Apr 29, 2012 | 05:28 PM
bnorris85's Avatar
Thank you!!!
Yay
(car looks like **** didn't think it would take this long to do the lights was gonna do wash and wax today too)
Old Apr 29, 2012 | 05:30 PM
bnorris85's Avatar
They were OEM, this is where I got em
part
INF B6000-CM40C
http://cgi.ebay.com/ws/eBayISAPI.dll...ht_1848wt_1163
I didn't swap the ground wire, i found in another thread that the 06s are grounded differently
Old Apr 29, 2012 | 05:55 PM
Condog's Avatar
Random question but what front grille do you have?
Old Apr 29, 2012 | 05:56 PM
bnorris85's Avatar
Sorry, I can't help you, it was on the car when I got it a few years ago
Sideview of grille (before headlight swap)
Old Apr 29, 2012 | 07:34 PM
itisallg's Avatar
isnt that the gialle grill?
Old Apr 29, 2012 | 07:36 PM
Illuminati's Avatar
Yes it is
