Does a Z-tube make much difference w/o pop charger?
Old May 7, 2012 | 06:14 PM
a471133's Avatar
Z tube w/ rev up airbox and amsoil drop in. Sounds a little louder above 2.5k.
Old May 7, 2012 | 08:07 PM
SAMzG35's Avatar
G35
I think it's more noise than anything else.
I have an AEM intake & plenum spacer installed. The car sounds awesome, didn't see any performance gain.
As for the relearn, I did it few times. It wasn't too bad. Just start the timer on your phone and watch the seconds.
Originally Posted by gary c
Good choice blues, the z-tube will change the sound and by adding a quality drop in filter you'll be fine. New Noob members don't realize when they add the pop-charger during warm weather it will cost them a ton of RWHP due to that aluminum piping heating the incoming air, that's called heat soak. Alternatives are Stillens CAI which is made of plastic composite or like I advised, an aftermarket drop in filter like AMSOIL or K&N....Gary
What do you think of the AEM intake? My car came with one
It goes all the way down under the headlight
Old May 8, 2012 | 12:05 PM
g35sleeper123's Avatar
intakes on our cars almost always do nothing if not a loss of power. best thing is just the drop in filter. lots of people are in love with the revup air box but i havent heard too much either way
Old May 8, 2012 | 12:17 PM
3n1gm4's Avatar
Originally Posted by That's G
Here's what some people said about this last week. Might help you out.
https://g35driver.com/forums/g35-cou...my-g-make.html
rofl
Old May 9, 2012 | 11:07 AM
atonal's Avatar
Originally Posted by that's g
here's what some people said about this last week. Might help you out.
lmao
Old May 9, 2012 | 02:08 PM
nghiars's Avatar
Originally Posted by 916TownG35
i hate the a/c rub with an aftermarket intake
what i did was took a rubber hose where the inner hole (gas lines will work) as big as the AC line and sliced it down the length of the tube and used that to wrap around the ac line where it touches the intake.
Old May 10, 2012 | 07:15 AM
Sylenz's Avatar
I recommend the Berk suction tube rather then the z-tube.
Frankieg35
Mar 20, 2016 09:42 PM
wonderizm
Sep 24, 2015 03:09 AM
avalino
Aug 6, 2015 01:42 PM
