Does a Z-tube make much difference w/o pop charger?
Old May 6, 2012 | 08:17 PM
blues3531's Avatar
Has anyone just done a z-tube mod? It seems everyone does it as a combo but I don't really care to. And I'm only doing it for the sound. Just want it to be a little louder thats all.
Old May 6, 2012 | 08:26 PM
NYT's Avatar
NYT
I just did it yesterday (z-tube & stock filter) on my 07 G35 coupe. Didn't notice much diff in anything.
I cleaned my MAF and throttle body too... now all I have is a funky idle
Old May 6, 2012 | 08:27 PM
Shanes_G's Avatar
you may have messed something up^ you mean mass air flow sensor right?
Old May 6, 2012 | 08:28 PM
blues3531's Avatar
Define funky...But thats bad news.
Old May 6, 2012 | 08:41 PM
herrschaft's Avatar
Originally Posted by NYT
I cleaned my MAP and throttle body too... now all I have is a funky idle
Did you disconnect the battery before messing with the throttle body? The idle relearn procedure may fix it.
Old May 6, 2012 | 08:42 PM
Shanes_G's Avatar
yea maybe..but its a PITA and very hard to get right.
Old May 6, 2012 | 08:44 PM
herrschaft's Avatar
Which is why I just disconnect the battery for approximately 20 minutes every time I need to reset something, finish it off with some spirited driving and everything works fine.
Old May 6, 2012 | 10:31 PM
Frankieg35's Avatar
For sound I would do z-tube with pop charger..
Old May 6, 2012 | 10:45 PM
916TownG35's Avatar
i just ordered a ztube. now waiting on the pop charger. hoping for good results
Old May 7, 2012 | 12:06 AM
gary c's Avatar
Pop Chargers "Suck Hot Air!"
Good choice blues, the z-tube will change the sound and by adding a quality drop in filter you'll be fine. New Noob members don't realize when they add the pop-charger during warm weather it will cost them a ton of RWHP due to that aluminum piping heating the incoming air, that's called heat soak. Alternatives are Stillens CAI which is made of plastic composite or like I advised, an aftermarket drop in filter like AMSOIL or K&N....Gary
Old May 7, 2012 | 07:54 AM
NYT's Avatar
NYT
No. Left it connected. Did a test drive and the idle was too high (1k) and didn't come down as fast when I let off the accelerator.
Then I tried disconnecting the negative for ~30 min and did some more driving (some very "spirited"). No change.
I'm trying to avoid having to do the idle re-learn (because I heard it's a PITA) so we'll see how the next couple days go - If the car/computer adapts a bit better or not.
Sorry to hijack
Old May 7, 2012 | 12:32 PM
Mark2K8's Avatar
Sound wise, def. I have the z tube w/out the popcharger and there was clear difference in stock g-tube and the z tube (at high rpm). At low rpm its the same.
Old May 7, 2012 | 01:30 PM
jgitt's Avatar
i installed a ztube and an apexi drop in filter friday and didnt notice much of a difference. Just a little bit of a sound changed under the hood. But im sure it didnt hurt me any. Like said above, a good quality air filter will go along ways
Old May 7, 2012 | 02:13 PM
That's G's Avatar
Here's what some people said about this last week. Might help you out.
https://g35driver.com/forums/g35-cou...my-g-make.html
Old May 7, 2012 | 05:20 PM
916TownG35's Avatar
i hate the a/c rub with an aftermarket intake
