Rear bushings
Old May 20, 2012 | 09:36 AM
TruGame's Avatar
Rear bushings
I need help , I was driving on the highway with 2 other car doing about 100-110 mph and when I was turning in and out of lanes I can feel the rear like... Sway a lil so I'm thinking I need changed the bushings but do I just need the subframe or is there more to it
Old May 21, 2012 | 01:29 AM
Th3R3dStar323's Avatar
mods dont like you referring to street racing, but anywho check your toe.
Old May 21, 2012 | 04:44 AM
TruGame's Avatar
I wasn't street racing we had to be there at a certain time so we had to drive a lil faster, so you think it's my toe not my bushings
Old May 21, 2012 | 05:24 AM
I wasnt saying you were but from what you said that is what a mod will think. It could be the bushings but it could be your toe as well. It is probably actually both. I fixed my toe which was really bad but i havent done my bushings yet and i i have just a tad of sway left. I used to not be able to drive when it was wet because i would litterally slide back and forth because my toe was so bad.
Old May 21, 2012 | 07:28 AM
TruGame's Avatar
Ok thanks I'll take the car to the shop today and ask them to take a look at my toe and bushings ,... Lol look at my toe
Old May 21, 2012 | 07:57 AM
getting a alignment done will tell you if your toe is messed up. Obviously getting an alignment done will bring your toe more back into spec. If after that then i would do bushings if it still not fixed. To tell you the truth it could be as simple as you needing new tires. The swaying happened when you went over bumps right? even small ones that are just noticable used to make me sway.
Old May 21, 2012 | 08:13 AM
TruGame's Avatar
I feel it when I turn & bumps but it was fine last week, .... Come to think of it I did hit a possum and it was caught it the lip of my rear rim some how , it was ugly
Old May 21, 2012 | 08:24 AM
Thats nasty lol you finally get it out?
Old May 21, 2012 | 08:57 AM
TruGame's Avatar
Yes it was nasty blood and guts all over my rim the side of my car
Old May 21, 2012 | 10:44 AM
TruGame's Avatar
Ok so I'm at the shop and he said everything look and feels on but the rear sway bar move up and down left and right
Old May 21, 2012 | 11:11 AM
Mr. Brett's Avatar
You need new sway bar endlinks and bushings.
I had a similar issue with my car feeling like the rear end wanted to step out when switching lanes on the highway. New endlinks and urethane bushings fixed that issue.
That's why your rear end is moving around so much...the sway bar's bushings are worn and can't do their job of keeping the suspension from flexing.
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
si_driver
Aug 11, 2015 07:08 AM
TreeFiddy
Aug 10, 2015 06:50 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
