DIY: TPMS sensor reset
Old May 21, 2012 | 11:50 AM
onthe3rdday's Avatar
I ate a curb last night and cracked my LF rim I went to NY and grabbed a set of rear 18's and moved my rear 17's up front. I had to reset the TPMS system afterwards to get the system to recognize the new sensors.
Procedure:
Set the tire pressures to the following values
RF34 RR26
LF31 LR28
Locate the TPMS Service connector by doing the following:
Remove the plastic panel directly below the steering wheel (you must remove two other panels to get to it), and taped to the OBD harness is the TPMS Service connector
Feed the service connector through the OBD2 data connector opening and then replace the plastic panel.
Back-probe the service connector with a paperclip or something similar, I used one of the probes from my meter.
Start the engine.
Ground the service connector to the chassis 5 times, about once per second.
Your TPMS light will begin flashing
Take a 5-5.5 mile drive and your TPMS light will turn off.
Immediately refill the tires to the recommended pressure... in my case 35psi. If you do not, the sensor will alert you with an annoying high pitched beep. Enjoy your dash with no TPMS light!!!
Old May 21, 2012 | 09:04 PM
dukehotty's Avatar
Awesome! I love this forum!
Old May 21, 2012 | 09:11 PM
Frankieg35's Avatar
Nice writeup.. why didn't u get a full set of 18s though??
Old May 21, 2012 | 09:13 PM
dukehotty's Avatar
Hey Frankie someone mentioned you in a recent thread.
https://g35driver.com/forums/brakes-...ml#post6458243
Old May 21, 2012 | 09:44 PM
Frankieg35's Avatar
Lol why all the h8!?! Don't be mad!! Lmao
Old May 21, 2012 | 10:19 PM
My 17s are in better condition and are wider. Temporary setup.
Old Jun 11, 2012 | 11:40 PM
Eye Eat Ketchup's Avatar
where did you ground the service connector? Is it long enough to reach part of the chasis?
Old Jun 12, 2012 | 07:32 AM
I removed the plastic fuse box panel on the left, grounded on one of the openings that the panel clips in to
Old Jul 5, 2012 | 01:30 AM
YOG35C's Avatar
Procedure:
RF34 RR26
LF31 LR28
Start the engine.
Immediately refill the tires to the recommended pressure... in my case 35psi. If you do not, the sensor will alert you with and annoying hig
h pitched beep. Enjoy your dash with o TMPS
l4184/2012-05-21102055.jpg[/IMG]
Wow, you must be some kind of hacker...lol good write up. 53/100
Old May 31, 2013 | 12:12 PM
G_DiRTY5's Avatar
Don't really know how to sub without commenting.
Old Dec 2, 2013 | 12:15 AM
Shawno72's Avatar
Good info
Old Dec 2, 2013 | 09:02 AM
Mustang5L5's Avatar
Its the procedure outlined in the FSM.
I've done this method a few times with success.
They actually make a tool for grounding the test plug. Not really necessary, but does make it slightly easier. You can probably make your own wire harness for $1 to do the same thing
Amazon.com: OTC 3831 Tire Pressure Reset Tool for Nissan: Automotive Amazon.com: OTC 3831 Tire Pressure Reset Tool for Nissan: Automotive
Old Dec 27, 2013 | 05:34 PM
COBRA ESQ's Avatar
QFTT !! Gonna give it a try (I assume it is the same for sedans?)
Old Dec 27, 2013 | 05:38 PM
Urbanengineer's Avatar
Yeppers.
Old Jan 10, 2014 | 10:48 AM
Google this, but why can't any TPMS sensors work for any car?
Simply amazon has a set of generic TPMS sensors for 50$, but the best value infiniti/nissan equivalent is 100$.
