Differential Help Asap Please
Old Jun 1, 2012 | 09:36 AM
kristinavq's Avatar
Will a 08 350z nismo differential bolt up to a 03 5at ?? thnx for the help
Old Jun 1, 2012 | 10:41 AM
kristinavq's Avatar
anybody ?? getting a good deal on 1 but dont want to pull the trigger uless im 100% sure
Old Jun 1, 2012 | 01:51 PM
SxExCx's Avatar
It should fit unless the pinion shaft is the other type. Even if it is different, you can just swap it from yours.
Old Jun 1, 2012 | 02:40 PM
herrschaft's Avatar
Doesn't the Nismo have a 4.1? Thats a huge difference from a 3.3
Old Jun 1, 2012 | 02:47 PM
Footballmania32's Avatar
Nismo OEM is 3.53. Aftermarket might be 4.08 IIRC. OP the diff should bolt right up. In case the input flange is a little different, like Sean said just swap over the flange from your current diff and it will drop right in.
Old Jun 2, 2012 | 02:45 AM
kristinavq's Avatar
Alright thnx for the help . Yall think 300 is good 4 the diff with 35k
Old Jun 2, 2012 | 03:24 AM
Silencer_0's Avatar
^ Not too bad. I sold my stock 3.5 w/vlsd and 27k miles for $300.
Personally I'd go with the 3.7 FD.
Old Jun 2, 2012 | 04:08 AM
kristinavq's Avatar
I was thinking about it but they said 3.7 ill lose some good mpg around town nd highway
Old Jun 2, 2012 | 02:51 PM
Silencer_0's Avatar
You'll lose a little mpg on the highway since you'll be cruising at a higher rpm, but it's really not that much. The extra acceleration is worth it, IMO.
Marlin84
Apr 1, 2020 12:52 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
_evilMonkey_
2nd Gen (V36) Sedan
Nov 22, 2015 06:21 PM
Dannyy06
Sep 25, 2015 11:32 AM
