Problem after installing test pipes
Old Jun 3, 2012 | 01:50 AM
midnighttheg35's Avatar
I just installed top speed resonated test pipes on my 06 6mt coupe. After installing them, my cel light came on (to be expected) but i also get a weird rattling sound while driving. It happens between 2 and 3k rpm and only when im fully off the gas. While its happening, if i press on the gas a little, or if i go into neutral, it goes away. It sounds like a high pitched rattling.
I dont know if this has anything to do with it, but the metal
Brace that bolts to the cats is not in as the top speed pipes didnt have brackets on them.
Any ideas?
Thanks
Old Jun 3, 2012 | 04:33 AM
kristinavq's Avatar
did you get them reasonated ??
Old Jun 3, 2012 | 04:45 AM
3truman's Avatar
its most likely rasp, whats the rest of your exhaust set up?
Old Jun 3, 2012 | 04:49 AM
Silencer_0's Avatar
They must be hitting something. Under load, they probably get shifted to where it has space, until you let off the gas. I'm not sure if this applies to your test pipes, but for ART pipes, it's required to trim down a stud on the driver side heat shield that's very close to the resonator and can cause rattling.
Old Jun 3, 2012 | 12:00 PM
3truman's Avatar
According to tony @ motordyne if you have a point in the exhaust where you go from a large pipe to a smaller pipe you can have rasp too. For example 3' to 2.5' or 2.5' to 2' which could be possible from the tps to the y pipe.
Old Jun 3, 2012 | 03:00 PM
Its not really rasp. Its like a chatter. Almost like a metallicy ping. My set up is just stock exhaust and headers with top speed resonated pipes.
Old Jun 3, 2012 | 03:42 PM
seymore4's Avatar
m56
Remove the heat shield that's next to the test pipes, sometimes it causes chatter like you discribed as the engine flexes during acceleration. Serves so real purpose either
Old Jun 3, 2012 | 03:55 PM
3truman's Avatar
It may be the bolt under the driver side seat or the heat shield then, i would check the clearences around the transmission too.
Old Jun 3, 2012 | 04:57 PM
seymore4's Avatar
m56
Also look into an uprev tune, now that you're running TP it'll make a
Huge difference and take care of that cel for good
Old Jun 3, 2012 | 07:22 PM
Jhambor's Avatar
9 times out of 10 it's the heat shield that is in the vicinity. Get under there and take a look for any low clearance ares and bend it or remove it if you need to. That's what I had to do.
Old Jun 3, 2012 | 11:57 PM
Alright ill check some time this week for the shield or bolts. Thanks guys!
Old Jun 4, 2012 | 09:53 AM
gary c's Avatar
Any time you install anything to your exhaust system and get noises only way to find it is to get er up on the rack. What size diameter are the test pipes, are you using the right size gaskets?
Gary
Old Jun 6, 2012 | 12:22 PM
Im just using the stock gaskets for now because infiniti said there ok to reuse. Ill see if topspeed sells some gaskets too
Old Jun 14, 2012 | 02:45 PM
thisiswang's Avatar
I get the same thing with my megan racing resonated TP's. everyone says to use OE gaskets and it should go away but i'm going back to stock cats
Old Jun 14, 2012 | 02:50 PM
Mr. Brett's Avatar
All test pipes with stock exhaust manifolds will create a chatter/hiss/rattle under deceleration. Mine do it as well between 2-3k RPMs.
My guess is that it has something to do with the exhaust flow, and the sudden change in diameter from the exhaust manifolds to the test pipes. The ID of the outlet for the stock manifolds is pretty tiny compared to the test pipes' IDs.
