Please help!!! Rear suspension noise....
Old Oct 31, 2014 | 06:54 AM
  #46
keithizm's Avatar
Clunking noise
I found the problem!!! Its the rear stabilizer bar bushing. Its cracked. Check it. Its a pain in the *** to remove, but $40.00 later, never heard it again!!!
Old Oct 31, 2014 | 09:41 AM
  #47
ununxium's Avatar
glad to hear YOU found YOUR issue.
Old Oct 31, 2014 | 09:14 PM
  #48
keithizm's Avatar
I attached a link to show the part I replaced. After having the car checked out at different mechanics, and spent a couple thousand, this little part caused me to nearly go insane. The one shown is superior to the OEM. I hope this helps someone.
http://shop.advanceautoparts.com/p/m...+bar+bushings#
Another sound I had a problem with before that was a constant "whirring" sound coming from the back of the car, that slowly got louder over time. It was a warped axle. The car used too much torque when ever I peeled out (cuz of my lead foot) and slightly bent it, Had to replace. See, I had a custom exhaust put on and between that and my stereo, never really noticed it until I started feeling a slight vibration when coasting. Again, I hope it helps someone.
Old Oct 31, 2014 | 09:22 PM
  #49
JKL1031's Avatar
Old May 16, 2016 | 10:28 PM
  #50
Phenomenon9's Avatar
I have the same sound and it's driving me crazy! I just replaced the rear shocks (KYB) on both sides, and I can still hear the noise when I go over a bumpy road or take a turn. My mechanic removed everything in the trunk and rear, but could not figure out what it was. He said nothing is loose and everything is in place. He said he gave up...
Sigh...any suggestions?
Old May 18, 2016 | 08:25 PM
  #51
Update: problem solved! The noise is gone! A user named Blue Dream in this forum was right. In another thread he said, "sedans have a grey X brace behind the rear seats. Over time the bolts holding it tight can loosen and cause the same sound you're describing. The fix is relatively simple, remove the rear seat backs, tighten the bolts with a little Loctite, and put the seats back."
rezendvous420
May 31, 2020 01:26 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
si_driver
Aug 11, 2015 07:08 AM
TreeFiddy
Aug 10, 2015 06:50 PM
atk08
Jul 30, 2015 03:12 PM
