Vibration
Old Aug 4, 2012 | 02:47 PM
options13's Avatar
WELL... i do know i have my lower control arm bushing SHOT, as in they are ****ED.. are you able to replace that bushing? or do you ahve to order a whole new lower control arm? the last shop i got my alignment was saying i can't get the bushing separately. and would have to pay $1200 to fix 2 little bushings...
Old Aug 6, 2012 | 02:01 PM
VMRWheels's Avatar
Originally Posted by JOKER
go to a smaller shop, if they give you same ****, tell them you just want it balanced to see if that eliminates the vibration before you get new tires for it.
Small shop should be able to do it without issues.
If vibration stays, you either have a bent rim (which you will be able to diagnose while getting it balanced) or a bad (or going bad) bushings in a lover control arm.
This!
Not balancing a tire due to camber wear is just them covering their behind so you can't turn around and say they did something that wasn't road safe.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
5150DS
Sep 26, 2015 07:47 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
